Need to replace thermostat batteries, can't open
I have an old (early 80s) thermostat in a not very accessible spot.  Can't remember how to open it to replace the batteries, and don't want to force it.  It's a dual setback model that was top of the line at the time.
Any ideas?  I know it's hinged somewhere, but can't really see where, and I remember it's somehow a little surprising . . .  just can't for the life of me remember how.
I sort of faked the category in hopes that it would come close.
Figured out how to take thermostat off -- not hinged, after all, but snap-off arrangement.
Thanks anyhow.
Posted on Nov 22, 2008
A video of installing lights on a 3 wheel early 80s golf cart
early 80s ? what part of the world
lots were made with different names
What Year is my Golf Cart
do you know the maker and model
or add a picture to your question
Mar 28, 2017 | Golf
I replace a radiator in a 1987 bmw 325 and it overheat when i drive slow
Did you replace the thermostat too? The thermostat is notoriously bad on the 80s 3 series. Also, be absolutely sure you added enough coolant. You need to fill the radiator, then wait until the thermostat opens, and add more. If didn't do this, wait until the engine is completely cool before adding the second batch. If you add coolant while the engine is overheated (or completely warmed up) you could crack the block when the cold coolant hits the over heated engine).
Jan 11, 2013 | 2007 BMW 525xi Sedan
I having a problem with my sharp up 700 cash register i purchased second hand and trying to program and it has got stuck in one of the menus and just states lacking memory
hi,im not an expert on tills,but inside you will find a re-chargeable battery pack,hidden under a cover.try disconnecting it for a few minutes and then re connect.it serves to hold its memory when un plugged,and this should reset the till to factory.i did this to a sharp till with similar issues around six months ago and it worked afterwards.cannot remember the model,but it was from the late 80s-early 90s
good luck!
steve
Jul 31, 2011 | Sharp Televison & Video
I can't locate the hazard flasher fuse on my 87 F-150.
About your 1987 Ford Truck F150 1/2 ton P/U 4WD 5.0L FI 8cyl...
Application: Hazard
The Flasher is located: Front seating area, driver side, driver side of steering column, behind lower dash panel, mounted on rear of fuse block
Application: Turn signal
The Flasher is located: Front seating area, driver side, driver side of steering column, under dash, mounted in upper left corner of fuse panel
Hope helps (remember comment and rated this).
Aug 05, 2010 | 1987 Ford F 150
I need to know what the following codes mean for a 1989 Dodge Ram. 12 24 35 52 17
12 Battery or computer recently disconnected (will occur on most cars most of the time, it indicates a low / missing battery happened in the last 50 key starts. Don't worry about it. — Tom Wand)
24* Throttle position sensor over 4.96V (SEE NOTE #3)
35 Cooling fan relay circuit open or shorted
52 Oxygen sensor stuck at rich position (SEE NOTE #5!)
OR
52 Internal logic module fault ('84 turbo only)
17 Engine stays cool too long (bad thermostat or coolant sensor?)
NOTE 3
Matt Rowe: “The throttle postion circuit tells the computer how far the accelerator is depressed. The Throttle Position Sensor (TPS) is on the throttle body on the opposite side of the throttle cable. The connector should have a round rubber cover over the connections. Clear the fault codes, start the car and try jiggling the wires/connectors to try to trip a fault code. Loss of this signal could cause other problems.”
Tom Wand: “Throttle Position Sensors (TPS) will on some early 1990s trucks start to drift high in voltage, there was a problem with these and the idle will not set low enough. Need to replace if it does this. As I recall, the output voltage at idle is 2.4 volts, much above is no good.”
NOTE 5
Wade Goldman wrote: In my case, the breather tube leading into the catalytic converter had rusted and become detached. This some how would cause the sensor to read an over rich condition and run crummy. I did not trust the reliability of the weld over a corroded surface and opted for the more expensive route of replacing the converter, breather tube and all.
More details can find in 80s-codes
Hope thats help (remember rated this FREE help) Good luck.
Jan 29, 2010 | 1989 Dodge Ram D-Series Pickups
How do i access the battery on my 80s 1100 katana please?
Hi, the early 1100 suzukis have a removable rear half of the airbox, under the seat, you have to remove it to get to the battery underneath, hope this helps :)
Jan 10, 2010 | 1993 Suzuki GSX 1100 FN (Katana)
Car turns over but wont start. I changed the spark plugs and wires, the distributor cap, fuel pump but it still wont start. seems to be getting worse not better.
I REMEMBER WORKING ON THE EARLY 80S MODEL CARS.I WOULD SCAN IT.IF YOU GET CODE 55 YOUR PCM FAULTY.IF YOU GET CODE 12 NO DISTRIBUTOR REFERENCE PULSES TO ECM OR PCM. POSSIBLE CAUSE OPEN IGNITION COIL OR BAD PICK UP COIL OR IGNITION MODULE.
Sep 22, 2009 | 1985 Cadillac Cimarron
Have a Vivitar v335 older model camera, think maybe early 80s. It's not digital, and need a battery. Several "experts" have told me a Duracell 28L is what I need but batter is too long. Battery compartment...
I happen to have one also. I bought it in the mid 80s. I still have the original box and instruction manual. It says: "Holding the Battery Compartment COVER in your hand, drop in and stack two LR44 or SR44 batteries so that the plus (+) signs are facing up. Replace the Cover. The positive (+) side of the batteries should face the (+) contact at the bottom of the battery COMPARTMENT. Turn the Cover clockwise with a coin until it stops flush with the bottom plate of the camera. DO NOT OVERTIGHTEN".
Sep 11, 2009 | Vivitar ViviCam 3915 Digital Camera
I have a polaroid onestep instant camera that is quite old. When I open the flash the light does not come on. Is there a battery or do you have to have film in it for the flash to work?
wow that is an old one. i had a polaroid land camera back in the early 80s and from what i recall the film insert did have what appeared to be batteries integrated into it.
Sep 24, 2008 | Cameras
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
