Humming noise when amp is switched on, nothing pluged in, make - marshall g30r cd
    Problem Solver:
  • 8 Answers
(Maybe) Seems like a problem with the reverb.Try opening it up (while un-plugged.) and try cleaning it out and checking there isn't any loose conections.
Posted on Nov 24, 2008
Marshall guitar amp humming noise
Boy, there are a bunch of things which can cause that, Jammy. First of all, is the wiring in your home, or at gigs or wherever providing an adequate ground ( I assume you have a 3 pronged plug to your amp). Does it do this everywhere? If it does,you've likely got an internal problem in the amp. i can't help you with that. There are too many possibilities. Is this a tube amp ? If it is ( I kinda think all Marshalls are), then I have no idea. I realize this is not answering your question, but the causes of the problem are vast. Take it in to a reputable guitar shop. That's my answer. . .
Mar 11, 2014 | Marshall Music
Guitar amp continuous humming from speaker
Firstly, do not disconnect the speakers from the amp when it is on. Damage is possible.
You have a bad ground somewhere in the hookup. The first suspect would be your guitar-to-amp cord shielding connections at each plug, then, the wiring in your guitar. Try changing each of these to another as a trial, one at a time.
Here is Marshall's spiel on hum
http://www.marshallamps.com/support/faq/hums-hisses/
Mar 11, 2014 | Audio Players & Recorders
There is no sound coming out of my Marshall 100 watt tube amp head?
make sure the standby switch is operating correctly.Sounds like the power tube.
Dec 18, 2013 | Marshall Amplification Marshall JCM800...
After a gig last night we tried our Marshall JCM 2000 DSL401and it had developed two noises without anything plugged in. The first is a transformer hum that I'd never noticed before and when standby is...
Likely the filter capacitors have a problem. Best to take this in for repair... it is ODD that there is noise with the standby switch is in standby... That makes no sense... In standby it appears that power is removed from the power amp high voltage so nothing should come through the speaker... Unles maybe one off the power tubes had a total meltdown which should have blown the fuse.
Sep 10, 2011 | Marshall Amplification Marshall Cover For...
Well i used to have this really bad guitar that has this grounding problem (humming all the time unless u lower the tone or touch the strings or any metal object on it) well i always blamed the guitar for...
This would only mean two things:
1. you have a bad capacitor in the circuit or the grounding on the circuit is broken and not filtering the obvious line noise from the circuit.
2. You have what is called, dirty power. That is when you have some kind of electrical device plugged that generates line noise which can be even a florescent light as they generate line noise.
Please take the following steps to narrow down the issue.
Take your setup and plug it in some where you know others can setup their rigs and it is using clean power. If, the humming goes away then it is dirty power where you originally setup.
If, it is still humming then you will need to take your equipment to a qualified marshall dealer have them look at it.
Jul 13, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
My Marshall Haze 40 Amp started making a very loud humming noise after a couple hours of playing.I let it cool down,and turned it back on and the noise came back after a few minutes
may be one of the electrolytic capacitors in the power supply has become leaky...this is a common problem among amplifiers...so you let it cool down..then after a period of time the capacitor heats up and then causes the hum...the power supply caps filter out the 60 hertz ac line noise...which is probably the frequency of the sound it is making...this is a good indication of these caps going bad....another thing you can check is to see if the amp is properly grounded(eg: the ground pin on the plug is present) and that you dont have an open cord or input
Jul 10, 2011 | Marshall Amplification Marshall Haze 40...
I get a humming sound when I plug my Gibson SG straight nto the amp. The noise fades and strengthens depending the positioning of the guitar in relation to the amp.
Your Gibson is sensitive to magnetic fields You need to keep the guitar about 10 feet away from the amp as the power transformer is radiating magnetic fields that is causing the hum. Solutions: there aree several... most are NOT practical... such as encasing the transformer of the amp in Mu-Metal shielding. Changing the transformer to a toroid type (they should deliver them that way) encase the amp in a thick steel cabinet... all this is ridiculous... putting distance between teh amp and the guitar is probably the only practical solution. The level given any particular orientation should fall off with the square of the distance. Note that OTHER stage equipment also will have transformers that radiate. Much of the new amps do NOT have power transformers that run at low frequency so they don't have this problem. Marshal is old school and they use the older power supply designs that radiate the magnetics.
Apr 16, 2011 | Marshall Amplification Marshall MG15FXMS...
Marshall MG100HDFX, VERY loud painful humming/noises as soon as the amp is turned on. Cant be adjusted by volume or anything, is this a connection problem?
Likely the filter capacitor(s) have failed OR the power amp has shorted driving DC with ripple into your speaker (very bad). Take it for repair before damage might be done.
Jan 10, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
Popping noise
Your welcome. I'm glad I could help and if it came that way marshall should do it for you.
Apr 25, 2009 | Marshall 15 Watt Guitar Amp
593 people viewed this question
 Grubhead
Grubhead
