Question about Zanussi ZWF1430W Front Load Washer
Zanussi zwf1237w washing machine
The main button comes on but no programmes work because err displays Hi, exactly the same problem. Doesn't matter what button I push "err" displays. Any suggestions, PLEASE! Please note this is a Zanussi ZWF1437 W.
    Problem Solver:
  • 8 Answers
I had the same problem my 3 yr old had been playing with the buttons and the whole thing just locked up and displayed ERR no amount of unplugging turning off would fix it.
Till ...........
  • Take off the top
  • Unscrew front panel and remove,
  • Then remove circuit board from panel,
  • Desolder the square battery,
  • Leave to stand around 15 Min's, (would recomend longer to be sure)
  • Re-solder Battery refit circuit board and refit panel.
This discharges the program memory chip and resets to default.
Hope this helps it's not so hard as it sounds just take care with the battery. DON'T put to much heat on it use a screwdriver on the small connections to act as a heatsink.
Posted on Dec 03, 2008
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Sep 25, 2014 | Zanussi Washing Machines
Why do i get 'err on display and buttons do nothing
err is error......should be a number or code after err.......
cheers
Jun 19, 2014 | Zanussi Washing Machines
All lights flash and error E90 shows on my Zanussi ZWF1631 washer
e90 is a cable problem linking main board to user board on the front
Jan 12, 2010 | Washing Machines
ZANUSSI ZWF1237W 2 YEARS OLD NOT WORKING
The motherboard is blown the part is covered under warranty which will take 4-5 days to come in and I have to pay for the labour.
Jan 22, 2009 | Zanussi ZWF1430W Front Load Washer
Reset
If this Err message is displayed constantly and the machine refuses to heed your attempts to select any programmes I'm afraid this means contacting the Service Force company who deal in Zanussi appliance spares, user manuals and machine dealings
Here is the contact phone number should you need it.
08705 929 929 www.serviceforce.co.uk
Hope this solves your headaches
Dec 12, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Zanussi ZWF 1631W
Try to pull out the power-cable from the contact. Wait for at least 30 seconds then reconect it again.
Sometimes that can help but not always. If that dosent help you need to let a profesional repairshop fix your machine.
Good luck
Nov 21, 2008 | Zanussi ZJ1217 Front Load Washer
Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Jan 24, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Washing machine
when any of the buttons are pressed ERR is displayed.
Jan 24, 2008 | Washing Machines
Won't spin at full speed. It just goes around slowly.
Jan 14, 2008 | Zanussi FJ1254W Front Load Washer
Zanussi err problem
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi ZWF1430W Front Load Washer Logo
436 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
