Question about Amana ARB1905C Bottom Freezer Refrigerator
Fridge is not cold but the light will turn on...
I just cleaned my fridge, and it was open quite a bit. The light is working, however the fan is not turning on and the fridge is not getting cold. I have it set on maximum cool. I have a Tempassure Amana...Is there a way to reset the fridge? Or....does it sound like we may need maintenance?
  • 11 more comments
  • Victoria Straub Jan 02, 2007
    We ended up finding the pressure switch inside the fridge (at the top of the fridge) Unplugging did not re-start the compressor and fan...It turns out the fridge had worked too hard and it set off the pressure switch. We also cleaned all of the coils to allow better air flow....It has been working fine so far!
  • rjrenegade Nov 24, 2007
    fan is running but not very cold. Freezer is the same way
  • trisha5 Nov 26, 2007
    My top refrigerator is not cooling enough, but the bottom freezer is working great. I had a repair man out and he couldnt find any reason why my refrigerator isnt getting cold enoug.. I have it turned all the way up to seven and still not cold enough. Help!!!
  • bertripley Dec 02, 2007
    I have a kenmore fridge that is not staying cold, it is three years old. the freezer works fine but the cold air is not going down to the fridge.
  • techiechick Jan 14, 2008
    I have the same problem, please tell me where to find the pressure switch or how else to fix.Thanks a lot
  • vinjojo Feb 20, 2008
    i have a hotpoint side by side my problem the product is 7 years old and
    i did have it repairs two years ago and is was working great i have my settings on e which is the highest any my ohter setting on 8 of which is aolso the higest what do i do lto get my refrigerator too make it cold do i have to
    call a repair tech to resolve this thank you
  • Nipper22 Mar 10, 2008
    We were away for 24 hrs. During that time we had a storm and lost power for a short period of time. We came home and the alarm was activated on the refrig. It was silenced by us. We noticed the lights were working in the refrig and freezer but everything was melting and going bad. Sounds like it is not running but has power going to it because the interiors lights work. Electrical panel did not trip. Unknown why it is not working?
  • bodastita Apr 01, 2008
    the fridge's light comes on but its not working the fan wont start
  • Anonymous Apr 28, 2008
    Fridge sounds like it comes on when doors open (lights turn on as well). Once the doors close it shuts off. It wont keep warm, and same with the freezer. Its been working fine for about 2-3 years. Nots sure what its is
  • DJACK10 Jun 10, 2008
    The compressor runs and the light comes on but the fan does not run. The
    freezer is cold but the storage area is not.
  • lrlar Jul 21, 2008
    I turned off the Frig to clean at the control box. When started back up the fan is working but the Refrig does not cool. I do not hear the compressor starting up.
  • glbuilder Sep 07, 2008
    hi fridge not cold but light comes on but fan does not run
  • Anonymous Dec 27, 2008
    my fridge is not getting cool but the lights are still coming on and the freezer is still freezing
  • 237 Answers
Try to uplug it for a few minutes then plug back in. Let us know if the compressor and fan kick on then otherwise we'll have to give more advice on where to look, etc.
Posted on Dec 26, 2006
Had same problem, but followed the unplug for a few minutes suggestion. While unplugged, got to back of fridge to discover back panel at bottom of fridge was dusty. Removed it to find that it was much heavier than appeared- cleaned, also noted fan had lots of dust- used vaccuum and toothbrush to get at hard areas. Plugged back in- happy fridge!!! Saved lots of time, $$$ and aggravation! Theory by total novice: heavy dust obstructed air flow exchange and caused overheating to fan. Next step, likely fan engine burn out and lots of expensive parts and labor, and who does that on a Sat night?! Relieved!
Posted on Nov 23, 2008
Help my fridge freezer engine is on, i can hear is in both fridge and freezer but not cold
Posted on Feb 22, 2010
It could be the thermomstat. You ideally should try shorting out the thermostat mains feed through so that mains get to the compressor motor all the time, if it runs and gets cold I should say the stat has gone. The trouble with this is you need to know about mains safety and use an insulated means of shorting the switch feed through without doing the wrong thing and blowing yourself up! If in doubt call an expert!!, George
Posted on Dec 29, 2006
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: Fridge is not cold but the light will turn on...
Hi, Has it been 30 minutes since you turned it back on? It might be in defrost cycle. Please let me know I can assist you further.
Vic
Posted on May 30, 2009
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | Refrigerators
Refrigerator not getting cold even when set at lowest point.
Not enough information. But here is something which may help you diagnose the cause. I assume that you have a frost free fridge freezer. That there is a fan in the freezer which blows cold air down into the fridge.That the freezer is still cold. You can hear the fan cutting in and out.
Try opening the Fridge door and locate the little plunger switch which is pushed shut by closing the door (like the switch on you car door that turns the interior light on and off).
Push it in manually with your hand. (the fan needs to be running. The fan should blow cold air into the fridge. There will be a panel with vents, probably on the back off the fridge. Cold air should be coming from this. When working properly the temperature sensor in the fridge will control a flap like valve to allow or disallow entry of cold air from the freezer to the fridge.This controls the temperature of the fridge. If the flap is jammed shut no cold air can enter the fridge. Likely cause is ice build up, most likly in the back of the freezer blocking the path of the cold air. I had this problem on an old fridge of mine.I think that it is caused by the heat cycle not kicking in correctly to defrost the heat exchanger . I used to DISCONNECT THE FRIDGE FROM THE ELECTRICAL SUPPLY dismantle the inner panels of the freezer. And pour water over the ice monster blocking up the back of the freezer. Not a good solution i grant you. But it would work for a week or two. Then i would have to do it again. later i found a small panel on the back (outside) of the fridge with wiring and stuff inside it. There was a rotatable knob which clicked as you turned it. in one position you could hear it make the heat cycle kick in manually. I spent about 6 months doing this every few days whilst saving for a new fridge. It worked. But there is a RISK OF ELECTROCUTION .
Sorry i cant fix your problem . But this might be of some help to diagnose it. If you are not sure i wouldn't recommend fishing round in the electrics. I have had quite a few electric shocks doing stuff like this because i am not as careful as i should be, and i am not a qualified electrician. It never hurts me much. But some people will die quite easily from mains voltage. BE CAREFUL!!
Feb 17, 2010 | Kenmore Refrigerators
Freezer is working correctly but fridge
hi there is a electronic vent that opens when cool air is needed and a fan ..to blow it up through channel.you need to find out if the fan is working first..open fridge door and push light switch in this should turn your fan on you should hear it hummmming. also put other hand were the vent is to fill if cold air coming through ..if not then you need to change vent assy. hope this helps,01179512835
Dec 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Vic
May 30, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Mar 30, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
Jenn-Air JFC2089HES (French Door) Fridge not cooling enough
Hey Northrock,
Did you ever get your fridge fixed? I have the exact same fridge and the exact same problem.
Nov 22, 2007 | Refrigerators
Not refrigerating
DO you have a thermometer to check the temp in both sections? MY first guess at the temp problem is that the fan has quit OR the vent betwen the freezer and the fridge is blocked. I bet on the fan being bad. Open the fridge door and hold in the little switch that operates the light. YOu should hear a fan running . If not, then the fan is kaput.. JOhnno.
Sep 16, 2007 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Amana ARB1905C Bottom Freezer Refrigerator Logo
12,500 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
