The right front passenger lower control arm bolt is not tighting up and is loose. how to fix the bolt and tight the bolt completely tighten.
If its the bolt that attaches to the spindle thats the lower ball joint u will need to jack up and support vehicle remove the wheel you will need to support control arm with a jack and decompress spring and chain or secure for safety reasons so it doesnt shoot out and cause injury cut or drill out the 4 rivets that hold the ball joint in place [if it is a pressed one will need to buy or a lot of auto stores will let you borrow a ball joint press]replace with new done ---if the bolt is the one attached to the frame need to do same set up and remove old and replace but the bushings are what will slow u down a bit while replacing
SOURCE: Driver side lower control arm, striped bolt.
can you email me a picture of the area ur talking about? blue_dragon45801@yahoo
SOURCE: starter
Good Day,
I've been in that same sitiutaion myself, best advice I can give you is to go to a hardware store and pickup some penetrating oil, liquid wrench makes a great penetrating oil. While you are there grab a small inexpensive propane torch. Soak the bolts with the penetrating oil for a few hours, then heat it up with the propane torch, repeat this process as necassry.
I hope this helps
SOURCE: wipers slip
some wiper blades have splines that locks the wiper to the shaft. take it off and look at it very close
SOURCE: I need to know how tight to tighten the head bolts
do u feel comfortable doin this-u need a repair manual and a torque rench-u must be able to read ft lbs on the tool and follow the book or else u can warp the head-let me know
Under the car.
Inside the engine bay.
