Question about IBM ThinkPad T40 2373 Notebook
IBM T41 WILL NOT STARTS UP SOMETIMESTHEN WHEN IT DOES IT FREEZES
I HAVE A IBM T41 LAPTOP WILL NOT START UP SOMETIMES AND MOST TIMES ITS OK AND AFTER A WHILE WHEN USING IT FREEZES UP
  • stevescot Nov 27, 2008
    does it make a difference to it (either making it start, or not) if you press just above the red mouse buttons(above the touchpad).
    if it does, you might have the same problem as me - apparently caused by solder cracking under the GPU,
    there are a lot of people saying you can fix this by heating with a heat-gun to remelt the solder - i've not tried this myself (but might do soon).
    to find other articles try searching for IBM T40 reflow gpu
    Steve
    Genius:
  • 1,019 Answers
problems will be with:-
1:- installed memory ( not enough or damaged memory module ) RAM
2:- The Processor ( CPU ) Is Overheating.
3:- Hard-Drive. The unit may have bad or defective sectors.
4:- Computer Virus Or Similar.
Solution:- remove 1 memory module from the computer ( located on the underside computer ) boot the computer. see if this helps. try changing memory between the 2 allocated slots.
Check the CPU Fan, is not clocked with dust/debris. ( Can be accessed by removing 2 screws on the underside or the laptop ) Marked with >> or similar. remove the fan, 3 small screws and brush with a soft dry paint brush or similar, remove any dust from fan and check for blockages.
run a scandisk or hard-drive checking program, to test hard-disk unit et,c.
following these steps, should solve your problems.
Mike @ Compurepair. " Thankyou For Using Fixya "
Posted on Nov 22, 2008
IBM ThinkPad
this can be solved...can you boot to safe mode, through F8?
Mar 07, 2008 | IBM ThinkPad T41 Notebook
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
IBM THINKPAD T41 LAPTOP GOES OFF OFTEN WHILES ON
IBM is very sensitive i have the same problem before check your processor fan and RAM. specially RAM causing automatic restart your laptop.
Jun 05, 2009 | IBM ThinkPad T41 Notebook
IBM Thinkpad T41 Freezes Randomly
THe heat issue would shut down your laptop or turn it off. This sounds like either a CPU problem or a motherboard. Most likely a motherboard problem.
Unfortunately, you need similar working parts to test physically.
Mar 13, 2009 | Lenovo ThinkPad T41 Notebook
IBM ThinkPad T41 (9 Cell Battery)
It can over charge it.
it happens alot with laptops.
Feb 04, 2009 | IBM ThinkPad T41 Notebook
I have an ibm thinkpad t41 laptop i upgraded to a 1gig ram i want to know if the grapics card can be changed or upgraded . I am trying to run 7 wonders game and it freezes up
the graphics cards really cant be upgraded with out major work. The game you want to run needs 512 of dedicated video memory, not shared as a laptop uses.
Hope this helps,
Thanks,
Mark
Dec 31, 2008 | IBM ThinkPad T41 Notebook
Ibm t41 thinkpad display problem
actually its the problem of the cable that gives display to your screen , open your laptop and replace this cable
rate this solution
Oct 15, 2008 | IBM ThinkPad T41 2373 Notebook
IBM ThinkPad T41 boot-up problem
Hello, enter BIOS (by pressing "Delete")and find there restore default. If you drop it you need check inside laptop of connections components. Check Cpu or Ram.
Sep 09, 2008 | IBM ThinkPad T41 Notebook
IBM T41 Thinkpad, not working properly
Do a system restore to a week or two before this all happend otherwise it may be the Hard drive starting to go bad if doing a system restore don't help and also you should run your antivirus and spyware Hope that helps you out
Dec 24, 2007 | IBM ThinkPad R40 2722 Notebook
IBM ThinkPad T40 2373 Notebook Logo
271 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
