Question about Maytag Dishwashers
Water leaking onto floor noted after dishwasher cycle
I noticed after the dishwasher cycle that the rug alongside the dishwasher was wet. this dishwasher is 8 years old. This is the second time it has happened.
  • 833 Answers
First, let's see if the unit is overfilling.  There is generally a float on the front of the tub which sets the water level.  The float jams because of detergent buildup.  Gently move it up and down until you get free movement.  That may fix it.  If not, check under the unit for leaks.  You'll see a wetter area where the water puddled...if it is coming from inside the unit.
Posted on Nov 26, 2008
  • Amy VanDer Kamp Aug 24, 2012
    How do you find this "float"? I know nothing about fixing dishwashers.
    Scholar:
  • 131 Answers
This could be many things,if its only happening when you run the unit i would look for either a door gasket,pump seal,or your lines going to & from the pump these are your most common leakage problems(if you don't know which is which then contact me & we'll see if we can isolate it.thanx for using fix ya
Posted on Nov 25, 2008
Why is our dishwasher leaking water
There are 4 places it could be leaking. 1) at the connection where the water line connects to the dishwasher. If the dishwasher has been in operation for a long time then this is not likely to be the problem. If this were the problem you would notice water even when the dishwasher was not running. 2) at the drain hose connection. You would notice the water during and shortly after a drain cycle. The drain outlet is usually a hard plastic over which the rubber drain tube is clamped. Either the plastic could crack or the hose could dry out and crack. 3) The seal around the pump could be leaking. 4) The door seal could be leaking, though this in not usually the problem. You can probably determine the problem by removing the bottom panel so that you can see underneath the unit, and then run a cycle. There are usually 2 screws between the door bottom and the lower panel (near the sides of the machine) and 2 more screws at the
bottom of the lower panel (the recessed part of the panel) near the sides. Don't stick your hand under there because you will have power to the unit and a wet floor. That is a bad combination which could be lethal. Just shine a flashlight under and see where the water is leaking from as it runs. Remove power at the circuit breaker before trying to do any service on the unit.
Aug 22, 2014 | KitchenAid Dishwashers
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 | Dishwashers
Our Jenn Air dishwasher leaks. We notice an
There are two possibilities here. First of all make sure the latch is adjusted to close the door tight. IF not, you can adjust it using a screw driver. next, you may have to replace the gasket as these do wear out.
Nov 03, 2009 | Dishwashers
Water leaked from bottom of washer
Check the pump right where the motor shaft goes into it. The pump seal can leak right there and the water drips directly onto the floor. It will continue to run out after the cycle till the remaining water drains out of the tub and drain hose.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Noisy cycle and dirty dishes
Hi
If your dishwasher seems noisy, check these:
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 25, 2009 | Kenmore 24 in. 17362 / 17364 / 17369...
LG dishwasher is dripping water from vent onto floor
Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
Water will not drain out of the tub all the way and behind the front door bottom in the insulation seems to be wet. and the cycle seems to take a long time to run...thanks
My dishwasher, Bosch Model No. SHU9922UC/U12, Serial No. 10 0202 80447 01 0040 goes through its wash, rinse and dry cycles but sometimes there is some water remaining on the items in the upper tray and one inch or so of water remaining in the bottom of the tub. Once water leaked out onto my kitchen floor. I found some broken glass and some plastic in the circular trap at the bottom and have removed the detritus.
Jul 29, 2008 | Dishwashers
Maytag mdb6000awb built-in leaking problem
it can be 3 problems. Most likely one is the seal from the acces apnel is leaking.
Or hinge of door is too lose or door seal.
My bet is on the seal for the acces panel.
HERE is drawing. However seal (#12E) is not drawn in.
You can also order the parts here and have them within about 3 days
Jun 29, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
145 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
