Sharp LC37D44U. Display in top right corner keeps coming on. It cannot decide whether the audios is "mono" or "stereo."
  • Anonymous Dec 28, 2008
    Same issue, no resolution...
    Any suggestions?
    Habit-Forming:
  • 166 Answers
I think you mean the channel/audio status display keeps coming on which normally indicates a poor reception (the channel beacon would come on when changing channels and then goes off) I think you should have your aerial system checked out.
SUPER8
Posted on Nov 24, 2008
My new sharp LC-52D65U tv continuously gives the sound display on the top right hand corner when it switches from mono to stereo etc. It dosn't do this all the time but for a while it will start again.
Make sure it isn't the source causing the problem. I.E. Cable box, dvd player, xbox or ps3. Try switching the wires. If all else fails, replace the main board.
Dec 05, 2009 | Sharp Televison & Video
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Sharp LCD tv "Audio window" keeps popping up on the corner
Replacing the cable box may fix the problem. But, you're the 4th person to have this same problem with this SHARP TV MONO only audio.
Try system reset button on the back of the TV or the box.
Feb 17, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
LC-37D62U Audio Input Issue
Reset the Audio setting to Factory setting.Should stop this.Still same problem,than ur tuner signal board is the problem.
Jan 11, 2009 | Sharp LC 37D62U 37 in. LCD HDTV
DIsplay box with keeps popping up-
I sent an email to Sharp and they answered
Dec 30, 2008 | Sharp Aquos LC-32D40U Television
QUESTION!!!
It may be a setting on the TV some stations only broadcast in Mono. But most likely check your tv settings and make sure it is in stereo mode.
Dec 22, 2008 | Sharp Televison & Video
My sharp 32 lcd keep flashing the channel and audio mode
If your receiver came with audio video cables, hook them to your receiver and to either input 1 or 2 on you flat screen. These inputs support audio video. This will stop that annoying flashing between mono and stereo.
Nov 30, 2008 | Sharp Televison & Video
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos LC-37D62U Audio Warning
Usually the settings can't be turned off and the audio settings are searching for whatever is being outputted from the program itself whether mono or stereo. It is nuisance I know.
Jun 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I just bought a Sharp Aquos LC-32D64U and a Box in the upper right hand corner keeps popping up "Air Analog Ch. 3 Audio Mono/Stereo." The audio keeps flashes either mono or stereo and it does...
The following pretains to most TV models:
Check to see if there is a key on the remote that is called "Display". This is normaly used to display the TV's operation status. Press it and see if you can work your way through different modes of the display content for the screen.
If you cannot make the statis dissapear, it is possible that there is a fault in the incoming signal and the TV is indicating this error, or it is possible that there is an actual defect in the set. At this point, I would contact the dealer. If you don't get a satisfactory answer, then you should contact Sharp service directly.
With retail dealers in many states and countries if you are dissatisfied with the set, you should be able to exchange the TV set in a specific period of time depending on the local laws that deal with consumer sales.
Jerry G.
Apr 13, 2008 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
