Hp psc 1500 constnatly blinks check printer cartridge and does no
T take the print job. However, when the stop/cancel and the color button are pushed simultaneously it prints well and also takes the message of print test page properly. Otherwise the test print cartridge keeps on blinking and precludes the printer from working. I have been refilling ink in the cartridges from time to time and it seems to be working well. when contacted the toll service service they seem to pursading the cartridge change. Bhawnani
  • 4,338 Answers
According to this HP document, the problem is with the ink cartridge(s):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00308379&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You may want to try a reset:
Reset the HP All-in-One Follow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 23, 2008
Hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
May 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Replaced ink cartlidge and now wont print
After replacing the ink cartridge you should print the alignment page to work product perfectly.
Follow the below instructions to print alignment page:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
If the issue still persists, perform semifull reset by following the below instructions
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the back of the all-in-one.
  3. Wait 30 seconds and plug the power cord back into the wall outlet.
  4. Plug the power cord to the back of the all-in-one.
  5. When the lights begin to flash, press and hold the On/Resume and Number of Copies Buttons.
  6. When only the On/Resume light is flashing, release the buttons.
  7. When the On/Resume light is steady, the reset is complete.
Oct 12, 2009 | HP PSC 1350 All-In-One Thermal Printer
"Incorrect Color Cartridge Installed"
You can just click the print button and the printing will begin, I was having the same problem.
Apr 05, 2009 | HP PSC 750xi All-In-One InkJet Printer
HP PSC 1500 xi Cartridge Error Problem
You do need both cartridges installed in order to use the printer. Even if one is near empty it will print (although your quality may suffer).
Jan 16, 2009 | HP PSC 1510 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
    5. Press Copies .
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Keep getting message Press Enter to Align Cartridges
after each alignment you press enter key or start key not cancel key,
Dec 12, 2008 | HP PSC 2175 All-In-One InkJet Printer
Replaced cartridges
try these... if the lights stops press cancel and color button together to self test. if it is working. the printer is ok! proceed to check for the printing Queue cancel all pending document, check and select printer on the print control ,
yours ,
alecz
Apr 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Hp psc 1410v
Could be a number of things. I would try looking in printer settings first. Click on your printer, go to properties and check all settings, it may be set to do this or similar. If no go, try uninstalling and reinstalling it, or just turning it off and unplugging, replugging and turn on again can often reset irregulariites. Also try resetting default printer settings too.
Apr 07, 2007 | HP PSC 1410v All-in-One Printer
2,111 people viewed this question
jasbo
jasbo
