Wash selector keeps turning around and not filling up with water
Sometimes it will work then sometimes it wont allso water comes from the bottom of the machine
  • 3 Answers
Sounds like you need to clear the pump?
Posted on Nov 23, 2008
600 model. Why does it start filling immediately regardless of selector switch position?
You have a fill solenoid stuck open. The solenoid is electrically controlled during the wash cycle and is only open when the wash cycle calls for water.
Aug 10, 2015 | Washing Machines
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
Washer does not stop filling up with water
hi it works on presure take lid off you should see a round or oval part clipped to inside of machine with about 4 wires going to it allso a plastic pipe to bottom make sure the pipe hasent come off if not its the switch
Feb 13, 2014 | Speed Queen ATS90AWN Front Load Washer
Have a Model 100 bosch washing machine will fill but does nothing after that .Doesn't seem to wanna spin or move Drum/
Try rotating the load size / water level selector switch back and forth. If this works, then your switch is going out. If it keeps on filling and doesn't stop, then your selector switch OR the level sensor (both located in compartment behind controls) is bad (probably level sensor).
The motor is locked out until the water level requirement is met, then the level switch allows the motor to be turned on.
Sep 10, 2010 | Bosch Washing Machines
Gcxrpo9odoww GE washer .. On fill up, it over flows onto floor?
Fill switch could be bad, or fill tube could be plugged making water not stop and it keeps filling. The fill tube goes from fill load selector switch to bottom of tub. Remove from top and blow it out. If this doesnt work replace water load size selector switch.
Jan 17, 2010 | GE WBSR3140DW Top Load Washer
Washer stopped filling. power still on. turning dial to different positions has no effect.
water level sensor not working or load size selector switch failed. could also be a failed water inlet solenoid valve. Turn it to cold wash and see if water fills again, if not turn it to hot wash and see if it fills again.
Nov 21, 2009 | Maytag Washing Machines
Kenmore 90 model 110.20912991 wont stop filling with water
If it continues to fill turned off or even unpluged, It needs to have the water valve replaced it is sticking open.
Jan 27, 2009 | Kenmore 15864/15862 Top Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
Jan 24, 2009 | Indesit W 123 Front Load Washer
Ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Nov 29, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
Top Washing Machines Experts
