Question about Canon LV 7345 Multimedia Projector
Projector does not turn ON
When I plug the AC power cord the lamp light indicator turns ON, but the 'Ready Light' does not come on. Pressing the power button does not turn the projector ON. The 'replace lamp' light is not ON so I dont know if the problem is the lamp or the projector.
  • Umar Sheikh Dec 24, 2006
    I tried taking the lamp off and then back on but it still doesnt work.
    Scholar:
  • 119 Answers
Try removing the lamp, usually quite easy, you need to find the door for the lamp. lamps are customer replaceable, usually. If the lamp is bad you can usually see it damaged in the lamp. kind of like you might be able to see the broken filament in your normale house hold light bulb. good luck.
Posted on Dec 24, 2006
SOURCE:
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
I replaced the lamp on my XGC55X Sharp Projector and it worked great for 2 nights (roughly 6 hours). Now it goes to warm up, with the lamp light blinking, and will power down with the status button showing...
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously INPUT, ENTER & UNDO on the projector, press ON on the projector. "LAMP 100%" is displayed, indicating that the lamp timer is reset.
If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary
Aug 06, 2011 | Sharp XG-C55X Multimedia Projector
I replaced the lamp on my sharp dt100 projector and now it will not turn on
Have reset the lamp hours after installing the new lamp? If, not the projector has treated the new lamp as old lamp & refusing to light further. So, reset the lamp hours to zero. To reset the lamp timer do as follows. Plug the power cord into the AC socket of the projector. Switch ON the power of the socket. (not projector) While pressing simultaneously MENU/HELP, ENTER & DOWN (button near MENU/HELP) on the projector, press STANDBY/ON on the projector. "LAMP 000H" is displayed, indicating that the lamp timer is reset. If this does not correct your problem then the problem lies in other area. Let me know so that further I can provide you solution. Above things are preliminary.
Aug 06, 2011 | Sharp Office Equipment & Supplies
I have a sharp xg-c55x. I put a brand new lamp. It worked once for about 20mins. Since then it starts warming up & then it turns off. How do i fix or reset? Thank you
Jul 07, 2011 | Sharp XG-C55X Multimedia Projector
I replaced bulb for Notevision PG-C30XU but how do i reset the lamp timer?
hi,
Do the following for reset the lamp hour
1.Plug the power cord into the AC socket of the projector.
2.While pressing down arrow, right arrow and ENTER on the projector a , then press POWER ON on the projector.
3."LAMP 0000H" is displayed, indicating that the lamp timer is reset.
ok
Feb 10, 2011 | Sharp Notevision PG-C30XU Multimedia...
I want to rest the Lamp timer of Toshiba Projector TDP-TW95 after replacement of New Lamp
hi
reset ur lamp timer through the following procedure
p { margin-bottom: 0.21cm; }
1. Turn-off the device by pressing the "ON/STANDBY" and unplug the power cord
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord
3. The lamp operation counter will automatically turn to zero
4. Check if the lettering "0H" appears on the lamp operation counter in the status display
5. After the lamp operation counter has turned to zero, turn off the projector by pressing "ON/STANDBY" and unplug the device.
ok
Jan 06, 2011 | Toshiba TDP-TW95 DLP Projector
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
EIKI XB23 PROJECTOR WON'T GO ON
Do you hear the fan start up? or does the projector lamp come on (you start to see an image)?
If yes to either:
When the temperature inside the projector reaches a
certain level, the projector will be automatically shut down
to protect the inside of the projector. The POWER indicator
is blinking while the projector is being cooled down. When
the projector has cooled down sufficiently (to its normal
operating temperature), it can be turned on again by
pressing the POWER ON-OFF button.
Note:
After the temperature inside the projector returns to normal, the
WARNING indicator still continues to blink. When the projector is
turned on again, the WARNING indicator stops blinking.
Then check the matters below:
– Did you provide appropriate space for the projector to be
ventilated? Check the installing condition to see if
ventilation slots are not blocked.
– Is the projector not installed near the ventilation duct of
air-conditioning equipment which may be hot? Install the
projector away from the ventilation duct of airconditioning
equipment.
– Are the air filters clean? Clean the air filters periodically. Let me know if you need to know how to do this.
If no to either:
When the projector detects an abnormal condition, it is
automatically shut down to protect the inside and the
WARNING indicator will be red. In this case, disconnect the
AC power cord and reconnect it, and then turn the projector
on once again for check. If the projector cannot be turned
on and the WARNING indicator emits a red light, disconnect
the AC power cord and contact the service station for check
and repair.
Please let me know if this helped solve the problem. If not, is there anything else you observed - whether or not you believe it's relevant.
1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Jun 26, 2009 | Optoma EP716 Multimedia Projector
PROJECTOR PROBLEM Casio XJ 31
it wasn't able to go through cooldown mode. turn it on, power down and let it go through cooldown. does the light come on at all?
May 31, 2009 | Casio XJ-S31 Projector
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Canon LV 7345 Multimedia Projector Logo
831 people viewed this question
Clive
Clive
old marine
old marine
