Question about NEC MobilePro 900c Pocket PC
Display has become almost illegible
My 900c has been working fine, but suddenly the display went very dim and is almost illegible. Type appears "reversed" i.e. white outline, not black The main battery shows 100% and backup "good". Any ideas to rectify?
  • hasko Dec 31, 2008
    Thanks a heap, that solved the problem instantaneously.
    Problem Solver:
  • 8 Answers
Maybe your Contrast is screwed up. Try soft resetting, then hold "Alt" and the ">" or "<" key at the same time. You can also see if you can turn up the brightness, using the two keys next to the delete key.
Posted on Dec 31, 2008
Digital speedo and display very dim on z750
Hi
Sounds like you have a faulty connector/wiring to the display unit, most likely a bad connector (known as a dry joint) leading from the ECU junction relay box. Dry joints/circuits a sensitive to vibration!
Getting the wiring checked by an auto electrician to make sure where the fault is actually in the wiring.
If the fault is a dry joint in the wiring, re-soldering the connector will fix the fault.
If the fault is a bad wire, replacement of the wire will fix the fault.
If the fault is a dry circuit in the display unit, replacement of unit necessary(costly & worst case).
Have a full Kawasaki service manual for the bike on an USB STICK in PDF form with you, when you take the bike to the auto electrician, it will help them find the fault quicker & cheaper.
If you haven't got a full service manual, you can download PDF file from the internet, the cost very minimal compared to a printed manual.
When I had my problem with the electrics on my Z750S, the fault was with the connectors(dry joints) and re-soldering them solved the issue!
Hope this helps
Apr 08, 2014 | 2008 kawasaki Z750
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
While working on my laptop it suddenly become blurry, the images are seems mirrored, the text become doubled and it hard to read. The graphics display was really blurry and even i open to safe mode still...
Look for a 9 pin or 15 pin plug on the side of your laptop. You can connect an external monitor to these type of jacks . If the display on the external monitor is clear then your laptop display panel is the culprit.
Jan 05, 2011 | Computers & Internet
Display got garbled, and locked up - had to force power down; on reboot no display. Turned laptop on this AM, and went on internet (google chrome) and then screen got garbled, lost mouse control, and had...
I think your inverter is good but the video chip is overheating or become heat sensitive. What you are experiancing I have seen before with regular pc's. Most laptops just quit working alltogether.
May 25, 2010 | ASUS G1S-A1 Notebook
Dim display on laptop LCD screen
The part you need is called a CCFL Backlight. Basically, there are lights in the screen that back-light/illuminate the display. Over time it burns out and you are left with a dim and completely dull display. These are a pain to replace and expensive when bought from the manufacturer. But this site has a break down with dis-assembly instructions...if you want to try it.
Mar 10, 2010 | HP OmniBook XE3 Notebook
The orange and black display on my NordicTrack T9 ci is very very dim. It is almost illegible. Doe anyone know how to troubleshoot this issue?
What your seeing is a common problem which I encountered on 3 separate displays. I have since diagnosed the problem and am currently life-testing a working solution. The real problem is very poor design of the negative voltage generator circuit for the display contrast. Everything else is working fine except that circuit. I have designed and installed in my treadmill a replacement circuit that is much stronger and am currently testing it. zubatcha@gmail.com for more information
Jan 22, 2010 | Exercise & Fitness
My NC-10 screen just went crazy. I can tap on the
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 29, 2009 | Samsung Computers & Internet
Display
A really dim display like you're describing is most likely a backlight problem.  If your inverter went bad you wouldn't have any display at all.  you need to get your backlight changed.
Oct 10, 2007 | Acer Aspire 5002WLMi Notebook
Display problem on NEC MobilePro 900
I just bought a 900C on eBay and had the same problem. According to the seller "the video cable on the right under the hinge cover gets loose..if its reseated it will be fine..you could just press on the bottom of the hinge cover right and it will make it go away but best to reseat the cable." I haven't tried his solution yet. Mine seems to intermittent since it is working fine right now.
May 30, 2007 | NEC MobilePro 900 Handheld
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Open Questions:
I WAS TRYING TO INSTALL JLIME ON MY MOBILEPRO 900, EVERYTHING WAS DONE AS PER THE DOCUMENTATION AS PER THE WEBSITE. AFTER ALL THE STRESS OF PARITIONING THE FLASH CARD.. I GOT THE FOLLOWING ERROR.. "ROOT=/DEV/HDA2" NOT found kernel Panic VFS cannot mount I dont understand a bit of this error.. i ahve tried all the zImage files on the website.. but still I am getting the same error. I used the Henchman.tar--------( All the versions avaliable on website" Haret.exe as kernel Bootloader file which read as below # boot a kernel with HaRET # # have the kernel zImage and the Haret executable in the same dir as this file # this file if named 'startup.txt' will automatically launch the kernel when you start Haret # # 'set MTYPE 659' is for the NEC MobilePro900c # # in CMDLINE change 'root=' to point to the location of your root filesystem # eg 'root=/dev/hda1' is the first partition on your CF card # and 'root=/dev/hda2' is the second partition # set KERNEL zImage-2.6.23mp900c set MTYPE 659 set CMDLINE "console=tty0 console=ttyS0,115200n8 root=/dev/hda2" bootlinux i have tried mentioning "hda1" , "sda1","sdb1","sdb2" I believe its not the problem with the Henchman file or is it??? I have the following partitions sdb1 as boot flag which is fat-1GB sdb2 which is of ext2-2GB sdb3 as SWAP-1GB i loaded the boot files in the Fat ie the Haret.exe Zimage and startup.txt file in fat system Please help me out in removing this error and getting Jlime installed in My Nec Mobilepro 900.. I used a transend 4GB flash drive
Jul 16, 2011 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c Pocket PC Logo
288 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
