Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
This is my 1st posting on this forum although I've done a lot of reading regarding the battery cover I think this is the correct solution.
To everyone that's having problems with the back plate battery cover warning messages or problems not booting up on your Dell PDA, I think I've found the answer, I have 2 Dell's PDA's, 1 a X51v & the other a X50v, I was having problems with both of them (1 had battery cover warning messages & the other had a screen freezing) so I stripped the 2 of them down when I had both rear shells together I noticed that the small piece of sponge that Dell fit to the latching mechanism one was on the far right of the latching plate on one & the other was in the middle of the plate, I looked to see which shell belong to which PDA & the one I was having problem with battery cover warning messages the sponge far right, so I swapped the back shells around & booted it up BINGO!!!!! problem solved, I'm fairly sure the SPONGE SHOULD BE IN THE MIDDLE OF THE LATCH PLATE, if I'm right Dell engineers & executives should be shoot, such a simple fix why didn't they let owners know about this. This has got to be easier than trying to bridge the switch contacts or rip the switch off the board, give it a go guys, Please let me know if it works on your PDA. I will upload some photo should any of you guys need.
sounds like a loose wire on the red 4 pin connector to get water temp filter pump must be running lost of times closing crews disconnect that stuff if that doesnt work give me more info
If the engine won't crank with compression in the cylinders, either the head gasket has blown or something else major has happened. You will have to get it towed to a shop. If it cranks normally but won't start, you have to figure out if it is a fuel or ignition problem. Did the temp gauge show it was overheating before it died ?
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Hello, most likly you will have to replace the whole cord assembly, here is a link to parts for you AC http://www.appliancefactoryparts.com/airconditioners/goldstar/m1003r.html
