Question about ASUS S478 VIA P4V533-MX Motherboard
AUTO TURN OFF
Guys i need help my computer is turning off automatically..
  • 31 Answers
Hello
go to control panel,select power option,under power scheme tab disable all if any select or filled & apply
if still having problem then try to scan your pc
if your pc turn off after a fixed interval of time then surely it solved by first method
Posted on Nov 22, 2008
How do I set automatic timer on AC1 Hozelock watering system?
incorrect operation. 1. Remove screws and back cover. 2. Insert two 1.5V 'C' Alkaline batteries. (Check + and - are correct.). IMPORTANT: Rechargeable batteries must not be used. 3. Replace batteries each season. (max 12 months use) MAINTAINING THE WATERPROOF SEAL 1. Ensure that rubber seal is positioned correctly. 2. Replace back cover and screw down tightly. 3. Repeat each time back cover is removed. HOW TO PROGRAMME THE TIMER There are two watering operations - Automatic and Manual. AUTOMATIC OPERATION Automatic ON 1. Turn dial clockwise to AUTO START at actual desired start time (e.g. To start watering each day at 15H00 you must set your AC1 when the actual time of day is 15H00). The timer has now memorised the auto start time until it is reset and will operate every day at this time. Use of manual ON or OFF does not cancel memory. 2. Turn dial anti-clockwise to: a) Chosen duration for once-a-day operation, or b) Chosen programme for all other watering frequencies (see table). The timer will now automatically run the selected program repeatedly until a new option is selected. GB 2 Automatic OFF Turn dial to Manual ON or OFF. If you wish to return to Automatic watering re-select the desired watering programme. NOTE your auto start time remains memorised until a new one is selected. Changing start time Turn dial clockwise to AUTO START at new chosen start time. Changing watering programme Turn dial to new programme. Do not turn dial to AUTO START unless a new start time is desired. MANUAL OPERATION Manual ON Turn dial anti-clockwise to ON. Water will flow for 60 minutes maximum or until turned to OFF setting. Note: After 60 minutes water shuts off. Knob will still point to ON and needs to be manually set to OFF or to desired number of automatic watering minutes. Manual OFF Turn dial clockwise to OFF. Note: Operation is only audible when valve opens and closes. To check that timer is working, switch to manual ON or OFF to hear valve operate. CONNECTING THE TIMER TO THE TAP Use supplied adapters if required. Tighten to ensure no leaks
Jun 25, 2018 | Hozelock Garden
Wipers running none stop in my mercedes c200
It's not a car I know well but if it is the one with the automatic wipers when water hits the screen then it could be the sensor on the glass even a bug splat right over it or you can turn off the automatic activation either on the stork or on the computer
Hope this helps or at least points you in the right direction
Jul 13, 2017 | Mercedes-Benz C-Class Cars & Trucks
Please my not less than one year old hp dv7 3165dx Pavilion is always shutting down minutes after startup...it never feels hott or wsrm to touch before this and the fan is working alright. No clogged up...
It sounds like your "automatic shutdown on error" setting is turned on. Here are the instructions to turn it off:
Restart the computer and press the f8 key to open the Advanced Boot Options menu.
Select the "Disable automatic restart on system" failure option.
Restart the computer to accept this change.
If there is an error, you will be able to see it after you disable this setting.
Mar 30, 2011 | HP Computers & Internet
Hi guys, did you ever had a computer malfunction for montero? My friends car automatically increase the acceleration while movinfg out a parking lot, causing him to hit the pharmcay in front of the...
99% of these kinds of unattended acceleration is driver error with a mix up between the brake and gas pedal.
Steering does not lock unless you turn the key to the lock position.
1% is a mechanical failure but switching the key off and depressing the brake usually controls the situation.
Jun 01, 2017 | 1998 Mitsubishi Montero Sport
My kodak m340 makes some clicking noise when taking videos, when i play it, i can hear the clicking in the background
The auto focus is what makes the sound. When the camera is in auto mode the sound can not be taken off. For videos and all other options on the top dial the sound can be taken away. Simply go into any mode on the top of the camera except auto; I chose video. click on the menu button and scroll down to AF CONTROL. Change from CONTINUOUS AF to SINGLE AF. This will knock out the auto focus from making that clicking sound while taking a video. The auto focus is the main component to the camera so it's really nice to have on all other dial settings; JUST NOT VIDEO!! :) Hope this helps you guys!
Sarah
Dec 16, 2009 | Kodak EASYSHARE M340 Digital Camera
IPhone 3G Battery Life
All of the iPhones have the ability to connect to an external battery, a charger, or any computer with a USB port. You only need a cable. Does your Treo charge from any USB port? And carrying a cable in your bag is no harder than carrying an extra battery.
I don't think you'll ever see a replaceable battery in an iPod or iPhone. It would make the device too big and it would reduce the battery life--that's right, battery life is worse with a removable battery because the battery has to be smaller. However, you can be sure that Apple will continue to push the chip makers for lower power chips
if this can't help you then add an comment i"ll solve it for you
Oct 13, 2008 | Apple iPhone 3G
Automatic updates
Hi ,
right click on my computer--properties--automatic updates--click on ---check box---apply --ok
check like this..........
Jul 02, 2008 | Computers & Internet
Disabling auto restart in windows xp
JUST FOLLOW THESE METHODS
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
HOPE SO YOUR PROBLEM SOLVES BY THIS SOLUTION
May 09, 2008 | Microsoft Windows XP Home Edition
Monitor turns on briefly then off
both of you need to do a complete over write restore and reprogram to recover the video card then install an older video driver program with the ability to lock out all updates. lala linda
Apr 24, 2008 | Nvidia Geforce FX 5200 Graphic Card
Contrast window keeps on popping in the monitor
Hi, it might be that a sensor in the monitor is sensing change in ambient light and therefore reacts by auto adjusting the contrast. when you push auto, it will do just that and auto react. Why not try manual and set it to your desired setting and let it run that way. But then again, of course it is possible that something is really wrong with the monitor and you would need a qualified service personnel to diagnose/repair it. Hope this be of some help and pls post again how things turn up. Kind regards.
May 18, 2007 | AOC LM520 (Gray, Silver) 15 in. Flat Panel...
ASUS S478 VIA P4V533-MX Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
