Question about Dishwashers
Error 'u1' on fisher paykel dishwasher
How do i fix this
    Problem Solver:
  • 10 Answers
Water Inlet Valve!
Posted on Nov 23, 2008
How do you fix Error code U1
U1 is displayed on the LCD as a "no tap" symbol. (time out on fill is after 175 seconds)
Possible causes:
• Water turned off
• Insufficient water supply pressure
• Blocked water softener filter (if fitted)
• Spilt rinse aid causing over foam in tub
• Incorrect detergent being used
• Motor rotor
• The machine is siphoning
• Inlet valve has failed
• Controller
Jul 08, 2014 | Fisher and Paykel 23 in. DD603H SS...
DCS bottom dishwasher drawer u1 code: begins cycle, runs a couple minutes then stops and beeps
Hi there Ypowers, U1 fault code relates to the fill system. Is the tap turned on, is the spray arm position correctly and free to rotate, nothing blocking it?. I hope this helps regards Gary.
Nov 08, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
After running for a while , about 3 minutes , a red light with the letters UI shows up and the machine stops its process .
Are you sure it shows UI or U1 . To help you check this Fisher&Paykel service manual and find among error codes. The manual is here!
Jun 03, 2011 | Fisher and Paykel 24 in. DD603H W Built-in...
U1 code 920 model filter is clean no hoses bent or kinked ? can it be fixed ? hans
The U1 code means:-
Dishwasher attempted to fill to correct level but failed. = Water tap not turned on. Turn the water tap on.
Too much foam. Rinse aid setting too high or has been spilled. = Turn the rinse aid dial to a
lower setting or wipe the spill. Incorrect detergent. Ensure that you use a detergent that is intended for a domestic automatic dishwasher. Egg yolk. Place an extra tablespoon of detergent in the dishwasher door for pre-rinsing.
Too much detergent. Use the recommended quantity of detergent
Wash pump faulty. Call your Fisher & Paykel Dealer or Authorised Service Centre.
Dishwasher not draining. = Drain hose bent or kinked. Straighten drain hose so water can flow through. Strainer blocked. Empty out the strainer and ensure the filter plate is clear of food
particles..
Feb 19, 2011 | Fisher and Paykel Dishwashers
Code u1 fisher& paykel model 920
hi, this tells you everything you need to know about a
fisher& paykel model DW820 and DW920 modelsi was also looking for the u1 error, and im sure my problem is being a male i use to much detergent (powder) that creates extra foam :o) oops lol but theres a list of things u1 error could be, i also found a few things out i wanted to know but googled before and found nothing. basically its better than the manual with everything you need to know. have fun.
http://www.fisherpaykel.com.au/admin/pdfs/pdf_usecares/521766I_DW920_ugm_NZw.pdf
if your computer doesnt read pdf files like mine didnt :( when you download and open it, it will ask to check internet for a program to download that reads it, in the list that shows i chose adobe reader 8, works well, anyway this will help im sure from max
Oct 14, 2010 | Fisher and Paykel Dishwashers
U1 Error and Washer Stops Working
"U1 error code" means the unit has failed to prime with water within 3 minutes. Its taking longer than expected to fill with water. Check the fill valve,it might be due to water supply problem, or the spray arm might not be in the exact position place.Check the above to fix this error code.
Thank you !!
Jun 22, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
Error E1
there is no e 1 error in dd603 , maybe u1 or f1 , u can call 1800650590 nd ask hem to send the use nd care manual , or download it from fnd p website ,
If it is U1 its saying taps not turned on , more than likey u have a F1 fault which is a flood sensor error , which means u need a new mains filter board around $50 to buy
Jan 31, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
We are now getting a U1 error code on a Fisher and Paykel Nautilus dishwasher which was in the house we purchased 3 years ago and has functioned perfectly until now. There was no manual left when we took...
U1 means the unit has failed to prime with water within 3-4 minutes.
Check the fill valve, water supply problem, excessive sudzing.,reduce your detergent.
Jul 27, 2008 | Fisher and Paykel Dishwashers
Fisher and paykel dish drawer
U1= Machine has failed to prime with water within
approx. 3 minutes
 The water supply is not turned on
 The machine is syphoning
 The spray arm is not in place
 Excessive foaming
 The Inlet Valve has failed
 The electronic controller has failed
 Rotor not fitted correctly
Jun 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
1,434 people viewed this question
Top Dishwashers Experts
