I set the fridge on Min and Refrigerator freezes everything even on the lowest setting. Anyone have a solution?
Is everything really frozen or just the top shelf stuff? You may have a thermistor (temp sensor) problem if the compressor just runs and runs and runs all the time. Take a glass of water and place a thermometer in it for about 3 hours then take a temp. reading. That will let you know what the real temps are. See if you can cause the compressor to kick off and on by changing the temp settings (go to real low for about 5 minutes then back up to high). Let us know what happens.
I can't wait to try this! THANK YOU for the suggestion!
Change temperature control
SOURCE: everything in my refrigerator is frozen even on
nothing to worry! just switch off your refrigerator for about 8hrs and after that switch it again. if it won't work than its time to replace your thermostart. because due to its falure only, the compressor is continously running and the temp. decreases. and all the metarials frosted..........................have a nice day :-)
Nope everything down to the bottom pull out tray is frozen and it never does kick off which I think is the problem. What would I need to replace in this case.
Thanks,
Matt
I am having the same problem, everything in the top shelf is frozen. So I need a solution. Andre.
When i put my Refrigerator on +7 overnight in the next morning everything is frozen. I dit a thermometer in the frige and the reading was -1, but the LCD display reading is +7. What can i do ????
fridge too cold, even on lowest setting
freezes
hi , our fridge at work is freezing everthing even when on less than 1 for the temp control. Could the Thermostat be broken?
control does not change temp of the refrigerator, everything freezes on every setting
