Question about Acer Aspire 5720-4230 Notebook
Acer Aspire RAM
Hi, I am not sure how to open the memory compartment on Acer Aspire 5720.
  • martin_hon Nov 22, 2008
    Thank a lot. But I removed all four screws and the covet still holds very tight. I do not want to break the plastic cover.
    President:
  • 1,901 Answers
There are 4 screws holding the cover on the bottom of the computer that allows access to the RAM modules. (This is the same cover that also covers the fan. The same cover with the ventilation slots.)
Simply remove the screws and lift the cover by the indent to the right of the battery lock.
Posted on Nov 22, 2008
  • Wayne Mineard
    Wayne Mineard Nov 22, 2008
    BTW, here is a link to the User Guide if you don't have one:
    Acer 5720 User Guide
    There is a picture on page 20, and the directions are on page 75. Good luck!
  • gffred83 Nov 03, 2010
    I think Martin already knows the obvious, like myself he is finding the cover 'still stuck'.
Tried installing 4gb memory on to acer aspire 5720z notebook running vista 32bit, they would not be recognised. Have now installed vista business 64 bit & the 2 x 2GB new memory is still not...
  • CPU Section:
  • Microprocessor Full Name:Intel Core 2 Duo processor T5250
  • Microprocessor Manufacturer:Intel
  • Microprocessor Speed (GHz):1.5
  • L2 Cache (KB):2 Mb
  • Frontside Bus (MHz):667
  • Memory:
  • Memory Speed (MHz):667
  • Memory Type:DDR2
  • Memory Size (MB):2048 Mb
  • Max Memory Size:2Gb
  • Hard Disk Drive:
  • Hard Drive Capacity (GB):80 Gb
  • Hard Drive Type:S-ATA
As you can see from my printout from the web site, this laptop doesn't appear to support more than 2Gb of RAM.
Sorry.
Oct 18, 2010 | Acer Aspire 5720 Notebook
MY Acre Aspire 3680 is Frozen! Need some Heat- appreciated :)
This one can do to remove the Hard Disk and try to enable it without hard disk.
if the problem is both are still remove the memory and clean it.good luck
Aug 15, 2009 | Acer Aspire 5720-6661 Notebook PC
Install RAm
Hello
Go here http://gd.panam.acer.com/home/ and take a look at the manual for the aspire notebook 5630 (should be similar to yours)
On page 39 theres a diagram showing the base. You basically have to unscrew the memory compartment cover , remove the cover then slot the memory in and put the cover back. RAM upgrades are really easy!
If you found this solution helpful , please rate my solution below
Kind Regards
1234s282
Jul 01, 2009 | Acer Computers & Internet
Where do you put the ram memory into acer 5720
Remove the battery and the power supply, turn the laptop over and look for a panel which is held into place with a screw, it will look something like this >>>>
Just push the lugs out at the sides of the slots and the memory will pop up, take it out and install the new memory, make sure it clips into place and is seated properly.
Good luck.
Jun 29, 2009 | Acer ASPIRE 5720-4649 Notebook
Repeated blue screen and reboot on acer 5720 laptop
It might not be virus problem, usualy blue screen happens when there is problem with the RAM memory or processor (more common is RAM problem).
Try taking your laptop to some service to be diagnosed with other memory modules - this will be the system of elimination of possible problems.
You can also try downloading some of the softwares for stress testing your laptop, like this one for example:
http://www.freedownloadmanager.org/downloads/Heavyload_39688_p/
If your laptop reboots before completing stress test, then you must take it to service for diagnostics.
Good luck,
Milan
Jun 01, 2009 | Acer Aspire 5720 Notebook
Ive got an acer aspire 5720 and the dvd/cd drive aint workin where can i get the driver for it
Have you tried the manufacturers website (i.e. Acer) and looked for the drivers there. They should definitly have them if you make sure you put in the make and model of your computer into the specific drop down boxes.
good luck
Apr 22, 2009 | Acer Aspire 5720 6497 Laptop
Installing Acer 5315 series memory
Laptops use a different type of RAM unlike a tower computer, the RAM is like little square pieces. Unscrew the cover, lift the old RAM out and replace with the new. Its located on the back or underside of the computer.
Jan 09, 2009 | Acer Aspire 5315 Notebook
Removing cover on Acer 5720z to access RAM
Download Aspire 5720 User Guide. Extract the .zip file and open the User Guide Acrobat File.
You can finr info on Installing memory on page 75
ftp://ftp.work.acer-euro.com/notebook/aspire_5720/manual/EN.ZIP
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size
Regards
Mike
Mar 22, 2008 | Acer Aspire 5610 Notebook
Acer Aspire 5720-4230 Notebook Logo
162 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
