Question about Plumbing
Trying to find the valve on the pump to release air
Just empty our spa for the first time an refilled it, an now it sounds like a washing machine, the pump make is flo master xp2
    Scholar:
  • 104 Answers
The pump is air bound. It should bleed by it self in a min or less. I would not run it more than that. Is there a valve on the output side of the pump to drain the system? If so open this valve while the pum is making the noise until it flows water, Should be right away) close the valve and all should be normal/
Good Luck
Posted on Feb 07, 2009
How do you service a lazy spa pump
If you mean it takes a long time to start up it probably has air in the pump. Most pumps have a little release valve you unscrew to allow the air to escape. When you first start up your hot tube after not using it for a while, you should release this air right away. It is hard on pump to let it run that way. You will need to remove a panel to access the pump.
Jun 17, 2014 | Pool & Spa
Our Jacuzzi hot tub was just refilled and the blower jets are not working. There is a loud sound from the pump but no air coming into the tub. Is there a air lock release valve we can try?
if your tub was not used for a bit of time your gonn have to pop open the sides and have a look around , Hoses that go nowhere or loose looking are what your looking for, plus water leaks , i did have a problem once with squirels getting inside one and eating hoses off ,made nest inside and generally messed things up inside it but any wild animal could do the same thing
Oct 25, 2013 | Jacuzzi Magnum Force Series Pool Pump 1...
I have just refilled by hot tub with a balboa 500z pump. After refilling it the pump is working fine but the jets are not. The dr light has come up. Please can someone help me bleed the pump to get it...
Priming can be done many different ways depending on thetubs design. Some tub manufactures provide bleed valves located on the plumbingjust beyond the pump and heater unions. Some pumps have a bleed valve locatedon the pump. If there are no bleed valves then you will have to release theunion nuts to allow the air to escape.
You can find answers to common spa or bath problems online at http://www.balboadirect.com/support.aspx
Hope that helps.
Jun 12, 2011 | Balboa Instruments Duplex Digital Panel 2...
I emptied my spa for routine maintenance and then refilled it. When I start it the pump works but I am not getting any action through the jets. I have never had this problem before and I have had the spa...
I would suspect that there is an air bubble trapped in the pump. Did you run the hose into the filter intake and confirm water was coming through the jets when you began filling?
Mar 04, 2011 | Pool & Spa
Self priming hot tub pump won't prime
If you have had the tub empty and refilled this could be an air lock and all you may need to do is open the drain valve till you get water out of it. Good luck
Aug 31, 2010 | Qca Spas Paradise Hot Tub
I replaced CVA-24 VALVE....now when I turn on pool filter no water being pulled through..no water being pulled through to pump
Your pump has probably lost its prime. This is either because it got too much air or not enough water. Try priming. This should make your pump start working again. Any time pool pumps have to be services, they need to be re-primed. In case you are not sure how, remove the pot lid and fill the pot with water. Re-add and clamp the pot lid. Open the air release valve on the filter and stand clear. Turn on switch or time clock. When water comes out of the air release valve, close the valve. If it is a two speed pump, make sure it is on high speed.
Aug 20, 2010 | Pentair 3hp Whisperflo Pool Pump In -...
Jet 1 won't turn on after refilling spa. Everything else works.
try turning by hand while off if turns ok try again see if voltage to motor if so bad capacitor or motor
Aug 13, 2010 | RTO Pump Volute, Acura, Maverick,No IMP
I attached a Skooba Vac to my 635 pump, which worked great @ first, but although I thought I had all the air out of the vacuum line, apparently some got into the pump. Now it won't fill with water. I have...
You can tilt the unit backwards as it is running and see if that clears the air out. The manual says to open the outlet valve first, wait a few moments then open the inlet. If that dont work then try the tilt method.
Jun 20, 2010 | Intex Krystal Clear Model 635 Pool Filter...
H20 error on Coyote Drifter Hot Tub
Air locks are a common occurrence after a drain and refill.
An air pocket gets trapped right in the pump volute, where the impeller is housed. So, the impeller sits in a pocket of air. It will spin there all day long, or until the cows come home, if they ever do? And you will never have water movement.
anyway, what needs to happen, is that air pocket needs to be pushed out of there! And the atmospheric pressure on the water in the tub will be your friend.
If you have isolation valves before and after your equipment, close the valve on the discharge side of the pump. Leave the suction side valve open.
loosen the union a couple of turns, on the discharge side of the pump, or one of the unions at the heater assembly, it doesn't matter which of the three.
You will get water, then the HISS of Air!
Let all the air come out, then water again, for about 3-5 seconds, then tighten. Open the closed valve. Start system. It should take off.
Good luck.
Apr 04, 2010 | Plumbing
My jacuzzi keeps emptying into the pool when the pump switches off and then refills from the pool when the pump comes on - do you know what the problem is?
I agree it sounds like a check valve. if the water in the pool matches the water level in the spa, or drains all the way (depending on how far the spa is raised) then it is the valve before the pump, but if it goes down to the jets (and not any further) then it is a check valve or valve on the retun side of the plumbing ( after heater or chlorinator).
Mar 13, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Plumbing Logo
170 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
