Question about Samsung HCM4215W 42" Rear Projection Television
Black screen . when I turn the t.v. on I get black sreen ,sometimes I get rainbow on the screen, before it went black convergence all messed up. any ideas . thanks ernie
    Genius:
  • 1,694 Answers
Replace convergence IC's,solder any/all bad connects.use OEM or better quality parts.
Posted on Sep 28, 2007
Thie PM when I turned on my SNES With out inserting a game pack the sreen was all in rainbow colors, when its mostly black then. Why would it show rainbow colors with the no game pack inserted then? Is...
If it still plays games, I wouldn't be to worried. These old consoles can be moody. You might try cleaning the dust out of it and check your AV or RF connector, (which ever you are using).
Good luck.
Mar 25, 2010 | Nintendo Super NES Console
Sreen not broke but the picture inside is when
If you see rainbow colors on the screen, the screen is cracked, you will need the whole panel assembly replaced.
Nov 03, 2009 | Sharp LC46SB54U 46 in. LCD TV
Sometimes I get a rainbow on the bottom of the screen.
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Philips 60PP9202 60" Rear Projection...
Im seeing triples on my screen when i use the menu and when i play a dvd theres like a black oval line on the bottom with a rainbow effect..
Need to replace the convergence amps, possibly some of the yoke return resistors and pico fuses in the convergence circuit,
Bill
Oct 30, 2008 | Toshiba 42H81 42" Rear Projection...
Appearing rainbow colour for sometime and getting off.
There are few cold (dry) solder joints in convergence board of your tv Sony KP-46WT500
Please inspect convergence board and resold dry solder joints.
Oct 18, 2008 | Sony KP-46WT500 46" Rear Projection...
Blury screen with rainbow image cannot read words on screen
The convergence integrated circuits have failed and most likely the 2 5A fuses have opened as well. I would find a local Mitsubishi service shop.
Sep 28, 2008 | Mitsubishi WS-65908 TV
Convergence nightmare
the convergence board wuld not solve the problem, you need the convergence power supply board for the ITC222 you can get one at the following link with free instructions.
http://servicemanuals.vstore.ca/
Sep 24, 2008 | RCA R52WH73 Projection Television
PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Nov 24, 2007 | Toshiba 53H71 53 in. Rear Projection...
Tv needs fixing, advice appreciated
it would intermittedly display a bowed rainbow effect and the picture would jump to that/black/back into focus. it was nothing but due to change of place due to decaussing ckt to take care of magnetic effect of earth. this morning i turned it on with a black screen. It has audio but no video. your problem it sounds me that it is due to loose contact or loose connector or due to video ckt. as you said that sudio is ok. if you are not tech person call skilled tech to fix it .it is not a major problem. hope this will help you please let me know what happened.
Sep 29, 2007 | Toshiba TP50F60/61 TV
Samsung HCM4215W 42" Rear Projection Television Logo
48 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
