Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
My miele megatronic dishwasher G5955C is flashing its outlet sign
It stops very early in the cycle
  • 51 Answers
SOURCE: Dishwasher not stopping
If it keeps going around then it is probably the programer timer motor unit. You will need to call Miele.
Posted on Jul 25, 2007
  • 4 Answers
SOURCE: The G638 finished its cycle but didn't completely
pump maybe on it's way out, though i doubt it, is the washing machine on the same drain out? if so you may have back wash, another could be lengh of drain hose, i had the same problem with my miele dishwasher because of the position in the kitchen i doubled up the drain hose and though it pumped out fine, with the volume of water left in the hose it came back in untill i repositioned the drain hose so it could't run back, hope this helps.
Posted on Aug 05, 2009
SOURCE: miele dishwasher red inlet light flashes
This is most probably a software glitch. I had the same issue a week ago and my dishwasher is only about 2 yrs old and only gets used on average once a fortnight.
At first I did everything as the manual shows in the troubleshooting section. The whole process takes only about 5 to 15 minutes depending on how good of a handyman you are.
When I cleaned all the parts involved (all pretty clean to start with anyway) and connect them all back, sadly the red light wouldn't go.
It looked like I was stuck with the most hated option I had left: call the dreaded technician and be prepared to depart with some hard-earned cash.
Before doing that and out of desperation, I decided to surf the net for clues, blogs, forums, etc... and on one of them I found my answer.
One blogger suggested that "if anything else fails, try the 'reset' step" which means pressing at the same time the On/Off button and the Start/Stop button. That operation put a big smile on my face (and my wife's face too) as the red light magically disappeared.
My suggestion is "first try the reset trick and if that fails try and clean the parts as the manual shows". It'll save you headaches because the reset would do the trick in 90% of cases.
I work in IT and I can understand the fact that a software malfunction would trigger the red light and not reset it.
Good luck.
Posted on Aug 14, 2009
  • 128 Answers
SOURCE: outlet/inlet light flashing on miele dishwasher G674SC
Usually indicates a intake or drain fault - could be a plugged drain line at the garbage disposal or insufficient water coming into the unit
Posted on Sep 23, 2009
  • 128 Answers
SOURCE: Miele dishwasher stopped, F84 flashing please
In most cases this means the circ pump is faulty - suggest calling a Miele service rep
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Miele G858SCVi Plus dishwasher intake drain button is flashing and washer will not fill with water. We had a pluged drain and tried to use a plunger on it and water backed up into dishwasher. After we...
If its been sitting a while, like 2 months or more, the circulation pump is locked up, need to call Miele, and they will send you a special tool to unbind the motor, its called a hook tool, they will send it to you free... works on the same principal as a garbage disposal tool....
Oct 09, 2010 | Miele 24 in. G656SCi Plus SS Built-in...
Outlet/inlet light flashing on miele dishwasher G674SC
Sep 22, 2009 | Miele Dishwashers
Aug 03, 2009 | Miele 24 in. G638 Plus Free-standing...
Miele dishwasher problem
good flow of water
Jan 12, 2008 | Dishwashers
Another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Nov 02, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Inlet/outlet light comes on
Machine is possibly not filling with correct amount of water if this light comes on early in the cycle
Aug 15, 2007 | Miele 24 in. G646SC Plus Free-Standing...
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
90 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
