Question about ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775 Intel P45 Intel Motherboard
ASUS P5Q3 LGA 775 Intel P45 ATX Intel Motherboard
This Motherboard takes DDR3 RAM......Dose anyone know if DDR2 RAM will work? I have read some fourms that say it will and others that said it dosent.......Help :)
  • 849 Answers
ALTHOUGH THE PINS WERE SAME BUT THE MODULE ARE NOT COMPATIBLE WITH EACH OTHER.
Posted on Nov 22, 2008
I want to extent ram ?does it supports ddr2 or ddr3?
Hi, i looked and the maximum ram it can take is 8gb of ram it supports ddr2 and ddr3 sdram.
Mar 01, 2016 | HP Computers & Internet
Will my Gigabyte GA-8I915P Duo Pro Motherboard take ddr3 and ddr2memory upgrades
This motherboard can take a DDR2 RAM , this are the supported RAM for it Dual Channel DDRII 533 / 400 or Dual Channel DDR 400 / 333.
Feb 11, 2011 | Gigabyte GA-8I915P Duo Pro Motherboard
Can i upgrade my ram to ddr3 if so what would you recomend .cheers
Thank you for the clarification sir.
NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
This is the support page for the Fujitsu Scalio 600 Media Center,
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
Uses either DDR Sdram at 333MegaHertz, or 400MHz.
(PC2700 and PC3200 respectively)
DDR Sdram has 184 gold plated contact pins on the bottom.
DDR2 Sdram has 240 gold plated contact pins on the bottom.
DDR3 Sdram has the same amount of contact pins as DDR2.
The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
Nov 18, 2009 | Televison & Video
Ram supported by asus motherbord p5p800-vm<green>
Memory should be same as the one that is in the motherboard . Each motherboard support only one type of memory. Search on the internet for the type of motherboard for memory supported with it. If it says other than DDR2/ DDR3 then the motherboard wouldn't support the memory. Do some searching like motherboaed p5p800 and see few websites for specification for the motherboard, check the memory specifically for the details.
Sep 18, 2009 | ASUS P5P800-VM Motherboard
Can I install DDR3 RAM chips on my laptop?
Sorry to say but that is not possible upgrading the RAM using a different RAM chip will not work, since your MOBO only supports DDR2 of RAM but if you just want to make the computer work faster you go and upgrade the DDR2 RAM up to 4GIG....
May 05, 2009 | Gigabyte GA-8PE667 Ultra Motherboard
Which is better 1gb ddr3 rams or 3 gb ddr2 rams?
No dubt about that! I would have take the 3gb ddr2 ram!
In a couple of years from now, when everything supports DDR3 i would have taken the DDR3, but today i take 3gb DDR2!
Nic
Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
Can i run ati radeon HD3650 512mb on asus k8N motherboard
firstly you need to make sure *********** board has a PCIe slot or a AGP... this is where your ATI HD3650 will go...see the graphic 512mb has nothing to with your main system RAM which is also 512mb.. so they wont be any problems as such and both will work together without any problems... but i suggest you to add another 512mb to your system RAM.. the difference between DDR and DDR2 is that... DDR2 is a bit newer and is faster in terms of memory read/write/access... do let me know if u have any futher problems....
Jan 27, 2009 | ATI RADEON X1650 Graphic Card
ASUS P5Q3 DELUXE/WIFI-AP CH1-11 LGA 775 Intel P45 Intel Motherboard Logo
267 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
