No sound in paltalk rooms
The only place I have no sound is in paltalk rooms . Sometimes I get a broken sound after 10 to 30 minutes , sometimes it works fine also after a while but it's very rare . Could it be caused because of my router ( edimax) ?
Thanks in advance for your help
  • 1 more comment
  • Anonymous Dec 10, 2008
    i have the same problem:-(
  • FATTYPETTERS Dec 27, 2008
    I HAVE A BRAND NEW LAP TOP AND WHEN I ENTER PALTALK ROOMS I HAVE SOUND FOR ABOUT 2 MINUES THEN IT KEEPS CUTTING OFF I ALSO HAVE THE SAME TROUBLE WITH MY PC PLEASE HELP
  • Scots1 Jan 13, 2009
    i have no sound at all, everyone else cam hear my music
  • 556 Answers
SOURCE: Monitor cause blasting sound !
as it is not always sometimes only. this might be due to over oscillation in horz. stage.means more eht. it might be due to 1 power supply seems to be more then normal. 2 horizontal frequrncy not tunned properly if any preset is there. 3 loose contact in hor. section 4 some times it is due to connecting cable from monitor to computer.
Posted on Sep 29, 2007
Cerfer39
  • 709 Answers
SOURCE: Freezes, no sound, won't turn on!
Hi Joeker, I believe you have a problem with heat. Also to get this problem solved, you need to open the main box and clean it up real good. I use a paint brush to dust off the circuit boards. Clean all the dust and lint out of the box. Put it allback together and make sure the main box has plenty of ventilation. do not set it on carpet, this will restrict it's natural circulation of air. I truly hope this helps you.
Posted on Oct 09, 2007
Riziel
  • 116 Answers
SOURCE: frequent disconnects with wrt300n
Ok for starters this wireless technology is still in it's early stages and is being tested while wireless G is still in play. Most of the time if you continue to get kicked off or get no connection at all, this is due to firewall settings. When a device connects to a router of any kind it must send and recieve a signal. Unless you have a static address on your laptop. (an IP address you placed into your wireless adapter setting) Your IP address sometimes changes, it does this when you turn off your computer, log off, etc. Sometimes when reconnecting to your wireless network the IP address changes because it is a dynamic address. A static address never changes. I have found that with some wireless technology devices if a firewall is setup with windows XP the IP address changes thereby not allowing the device to reconnect to the network or be recognized based on the IP change. I have found this alot with wireless printers, external Network storage devices, etc. Sometimes when you take down the firewall your computer will reconnect to the network. Or just go back to the basics: Right click onto the wireless icon at the bottom right near the clock. You should have an option asking you to repair, this helps most of the time.
Most common problems with having be disconnected from your network is when you have a laptop and you use it outside of home on or in another location. Any more questions I have tons of answers. I can also walk you through a network setup!
Posted on Nov 26, 2007
  • 556 Answers
SOURCE: i cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Posted on Dec 06, 2007
mksadik
SOURCE: MK241H sometimes doesn't turn on
Unplug the monitor from CPU Keep the monitor alone and see any problem. If not try to plug to some laptop and check again. We want to sort out the problem from monitor or CPU..
Posted on Dec 12, 2008
What causes mower deck to sometimes engage after PTO switch gets shut off.
Sounds like a bad connection in the wiring harness from the switch to the PTO clutch. I have a lot where the wires broken at the clutch but still make contact randomly since the insulation was still in place.
Aug 11, 2014 | Garden
I have a hp laptop and its a good pc i do play alot of music on it and its sounds good however when i try to play into a chat room like paltalk it plays for a sec then cuts in and out in the room but on...
Hi friend,
firstlt go to the control pannel and select the open printer and faxs,right clieck on the printer and set to online.
Thanks,
Please rate me........
Jul 03, 2010 | HP (400745-001) Sound Card
My sound cuts in and out
I'm not sure I understood correclty, but it sounds like you're listening to something on the web. If this is the case, than it mens that the connection is to slow and is interrupted. I would like to request you to listen to audio files on your computer, let's say any MP3 music file, and open it with the Windows Media Player installed on your computer. If it works fine, than there's nothing wrong with the computer.
Apr 13, 2010 | HP Pavilion dv6000z Notebook
Brake problem
It sounds like your rear brakes needs to be service. Your brake shoes are worn too thin or the retainer clips are broken holding your brake shoes in the right place. Good luck
Apr 06, 2009 | 2001 Chevrolet Cavalier
Paltalk bootings
May u have loss your audio software from computer or u may have uor software problem
Mar 02, 2009 | Microsoft Windows Vista Business DVD...
Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
Dec 03, 2008 | Heating & Cooling
HVAC
usually the compressor is broken. its inlet valve and the exhause valve sometimes are not as gastighten as before.
if that is true, your room cannot be cooled down.the compressor has to be replaced.
May 28, 2008 | GE Zoneline AZ55H09D Air Conditioner
Computers & Internet Logo
954 people viewed this question
David Payne
David Payne
