Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Front Door Digital Control Panel keeps cycling
I accidentally pressed up against the control panel on the front door of my Kenmore Elite bottom freezer refrigerator when working over head. It started beeping and now continues to cycle through all the ICONS and I can't get it to stop. Conseqently, I don't know if my refrigerator is running or not.
When I called Sears, they just want to send out a service technician, apparently there is no one who can instruct me over the telephone.
I'm hoping you all can give me some instructions.
Thanks in advance for your assistance.
Regards,
Ann Conrad
  • dkri Nov 27, 2008
    Same problem - control panel cycles thru all the settings. Does not seem to be cooling properly.
    Problem Solver:
  • 4 Answers
Though I received no FREE support from FixYa (as advertised), after a restless nights sleep I figured out what to do, as I discovered in the morning my refrigerator had indeed stopped running.
Just to provide some background info, this new Kenmore refrigerator was larger than the one it replaced, however I managed to accomplish a near impossible task and squeeze it into the same space, thus it was there to stay, because moving it in and out again was an unlikely task.
Back to the solution. I decided I should try turning the refrigerator on and off. Since I could not locate any controls inside the refrigerator which would turn it off, my only option was to pull the refrigerator out of its very tight space and unplug it, which is exactly what I did. After 60 seconds I plugged the refrigerator back in and ta-da!!!, it refrigerator started running and the control panel stopped cycling and held the initial settings.
I have to admit, I have not attempted to push the refrigerator back into its space, as that is not a feat I'm ready to face.
I hope this common sense solution helps others in need, although they probably will figure it out on their own much faster than I did.
Have a GOOD day!!!
Regards,
Ann
Posted on Nov 22, 2008
Control locked is lit up and not allowing me to start another load of laundry. What do I do?
Please avoid answering questions of which you know NOTHING.
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
(tip courtesy JS Rock)
Thanks for using FixYa
Feb 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Locked controls
If you are referring to the Control Lock on a Whirlpool Duet, Kenmore Elite, or Maytag Epic series front loader, this is actually a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
The following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue).
NOTE: Each one of these washers come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot if you cannot get the control panel to unlock.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
Feb 03, 2011 | Kenmore Elite HE4 Electric Dryer
WhirlpoolGB AWO 3751 Door firmly shut but red door locked indicator starts to flash and programme will not start.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Get the unlock off
Check out this tip that I wrote, it will tell you how to get into the washer manually...
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Apr 19, 2010 | Kenmore Elite 45986 Front Load Washer
I have the Kenmore Elite HE 3T frond loading wash machine. The door will not unlock. I tried the rinse and drain cycle but that's not the issue. Please help! Is there a "reset" button I can press to cancel...
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Showing ''cl'' on the front pannel.
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Mar 13, 2010 | LG Washing Machines
My whirlpool duet 2004 front load washers door is locked, time is flashing and pump is on. Unable to stop or open door. tried to unplug. Control lock is not on. My wife tried to add clothes when the add a...
Sep 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t Washer Control lock lit, door locked
121 MINUTES USUALLY DRAIN CYCLE PLZ REMOVE 3 BOTTOM PANEL SCREWS 7 MM SCREWS, TO OPEN DOOR SLIDE RIGHT HAND TOWARDS DOOR LOCK ,THERE WILL BE A SMALL LEVER TOO PULL DOWN ,NOW ITS OPEN,,, SINCE U HAVE BOTTOM PANEL OFF PUMP IS RIGHT IN FRONT REMOVE PLASTIC HOUSING CLOCKWISE ,,,REMEMEBER HOLD 3 GALLONS OF WATER STILL ,HAVE BUCKET READY ,NOW CLEAN OUT PUMP AND DEBRIS ,, CLOSE IT UP SHOULD BE FINE NO MORE PROBLEMS ,,,,,
Jan 01, 2009 | Kenmore Elite 45986 Front Load Washer
Control door lock light stuck 'on'
Unplug it for 40 minutes to reset.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
129 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
