Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Psp homebrew FuSa
Um like what cable do i use
like all ends white red yellow or one end those colurs and the other black i have know idea i am confused i all ready installed its for 5.00m33-3
    Sergeant:
    Champion:
  • 236 Answers
The cable you are describing is the A/V cable. it is used to display the PSP on your TV.
the cable you need to connect the PSP to a computer is a mini-b USB cable.
just go to a store and ask for a USB cable for your PSP.
Posted on Nov 23, 2008
Connecting Alba DVD to Toshiba TV
If the TV has the red, white and yellow sockets on it you can use an adapter. It's a scart plug on one end (for the DVD player) and 3 little round sockets on the other, usually red, white and yellow, sometimes red, black and yellow, like this:Amazon.
Then you need an audio/video lead with red, white and yellow plugs on both ends like this:Amazon
Or one of these:Amazon
You could also use a multi socket scart adapter to add more scarts to your TV:Amazon
Jan 23, 2012 | Toshiba Televison & Video
Tip
Play psp games on tv via composite/component av cable
you will need to have:
1.a psp slim with custom firmware 3.80 or 3.90.
2.composite/component av cable.
3.installer plugin file FUSA that can be sourced in the internet e.g. qj.net.
4.memory stick pro duo with 2 gigabytes capacity.
steps:
1.source the FUSA installer file.
2.once sourced,extract it to your pc desktop using 'winrar'.
3.connect pc to psp via usb.
4.upon extraction,copy or drag all four files (prx and txt) to the 'seplugins' folder on the memory stick (ms0:/seplugins/).
5.if you don't have the 'seplugins' folder on the root of the memory stick,create it.
6.exit usb connection and completely turn off psp,then turn it back on while pressing the 'R' button to go to recovery menu.
7.on recovery menu,choose and click plugins,set the FUSA plugin to 'enable',then exit recovery menu.
8.you can also activate the plugin on the FUSA menu itself,and this is better recommended.
9.connect now psp to crt tv using component av cable.
10.load a game and after loading it,just right before clicking the 'start' button to begin play,exactly at this point,simultaneously press on the volume - and + buttons to bring out the FUSA menu.
11.after a few seconds,the FUSA menu will appear on the psp screen,change the settings accordingly,exit FUSA menu and start the game to play it on your tv.
*many games or emulators will work but not all as the FUSA file is still in its beta stage,you need to figure out which one will work or not through trial and error.use caution,this guide works but no guarantees.
*used a 2 gb memory stick pro duo as 4 gb didn't work.
*used on an interlace only tv and not progressive or crt/non-flat/lcd/plastma/hdtv's.
thanks.
on May 05, 2008 | Sony PlayStation Portable (PSP) Console
The connector that connects to the phone has been broken off from the 4 wires..(RED/BLACK/GREEN/WHITE...On the end of the connector there are 4 holes..I just need to know the order of the wires..THANK U 4...
left to right black red green yellow only two wire operate a phone red and green for one line and black and yellow for the other line so you can run two line down one phone cable as long as red and green are in the center.
Feb 05, 2011 | Computers & Internet
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
No colour when watching dvds ok for everything elese
You will have to make sure you are connecting them with the red and white cables on audio and the yellow on video at both ends, as both your dvd and tv have low def and hi def cabling options.
That means Red and White to Audio at each end and Yellow to video at both ends. If you connect the yellow cable to one of the other three connectors at iether end you will only get black and white as they are meant for a different type of connection.
To get the maximum quality out of your sets you may want to purchase a set of Hi-Definition Component cables which will give you a set of five cables, still red and white for audio but now red, green, blue for video.
Hope this heps a bit more,
Chris
Apr 30, 2009 | Panasonic DMR-ES35VS
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
How to hook up video game to my lcd samsung 1080p
on the ps1, connect the cable that has the Red, White, and Yellow connections on one end to the black connection that looks flat (or both ends if you have the model with the Red, White, and Yellow connections on the back of the PS1).
connect the other end (red, white, yellow) to the TV with the same colors, on the same row. Note the input name (video 1,2... or aux 1,2...).
turn on the PS1. On the TV, change to the input name that you just connected the ps1 to.
you should see the ps1 menu.
Aug 24, 2008 | Televison & Video
What type of file can be stored in firmware 4.1?
Yes, if you are running a Custom Firmware on your PSP, you can run homebrew apps and games on it...if it has the ReadME file, usually, it has instructions in it...but I know most of the homebrew runs from the folder GAME or GAME3.XX / 4.XX. You'll know if you're running a custom firmware if it says on the System Info, it has a m33 suffix at the end of the firmware version (e.g. 3.90m33-2)
Jul 27, 2008 | Sony PlayStation Portable (PSP) Console
Setup
I went to 'S' video for that function and use the external audio inputs for L/R. This path is slightly superior for video but carries no audio signal.
Check to see if they both have it.
The yellow cable is normally a 'composite' video cable which carries video and sync info.
The red and white are pretty standard for audio with red=right and white=left.
May 25, 2008 | Olevia LT32HVM 32 in. LCD Television
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
83 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
