Question about MA Audio Hard Kore HK-898 Car Audio Amplifier
Technics amp su-vx800 goes in to protection mode after approx. 10 to 15 mins of play depending on the volume level.switch it off for 2 mins and it operates again.Could this be a faulty muting ic AN7073, a driver transistor or other faults.
Check Emitter resistors and transistors in protect circuit, freeze spray can sure help isolate on the run - as the thermal characteristics change so does resistor values (to a degree) and transistors - leaky ones can trigger this too... however do not discount you may have been had by a dry joint.....
- Baily
Posted on May 02, 2009
    Scholar:
  • 120 Answers
Yes it can, it sounds like its over heating, make sure that your product is able to get fresh circulated / cooler air
if it already is, then it probably is a faulty product.
Posted on Nov 23, 2008
Technics su-g75 amp goes to loud static after a few minutes
Hi Aawpharmd,
system control error.
please go for repair shop.
regards,
nuwan
Jan 13, 2014 | Technics SU-G75 Amplifier
I have a Technics ammplfier SU-V4X after playing for about 5 mins it cuts out , it gets over heated . what can I do to stop this.does it have a fuse I can remove
you will have to cleac dust or debris from fan exhaust and filter, can cause it to go into shutdown. Amps will do this to protect them from damage. Regards, meder's tv service
Oct 01, 2011 | Technics SUV500 2-Channel Amplifier
I have a technics SU-v500m2 amplifier connected via the aux input to my pc, i wish to link another amp to the same input, is this possible, and if so how?
Let's establish which is the IN and which is the OUT here. The PC is a Line Level source so its OUTPUT would feed one of the amp's Line Level INPUTs.
What's the second amp going to do in your scenario? Something other than the normal stereo channels; something multichannel (if your PC supports it); or just more speakers supported for the PC to feed?
An RCA Y-connector pair would share the stereo output of the PC with multiple Line Level destinations.
If a second amp with its own volume control is intended to share the same two channels with the SU-V500 it could also be slaved off the back of the SU-V500 wih an RCA patch pair exiting the Tape 1 or 2 REC(OUT) jacks. The second amp would receive full-volume audio from whatever source the SU-V500 is playing. Just don't activate the selected Tape monitor on the SU-V500 or you will cut off the source to both amps.
Sep 24, 2011 | Technics SUV500 2-Channel Amplifier
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
Su-v55a technics amp cuts off when volume up to 2
usually meens it is protecting itself from destruction
check your wires and speakers for problems
Feb 09, 2010 | Technics SUV500 2-Channel Amplifier
Technics SU-G75
I had the same problem. The solution to me was presoldering transistor Q708. http://www.flickr.com/photos/37147023@N03/3511227679/?edited=1
Feb 05, 2009 | Technics SUV500 2-Channel Amplifier
Denon AVR-1508 Receiver problems - cuts off and goes into protect mode
Usually when the unit runs for a while before shutting down there are two possibilities:
1) There is a small amount of DC current present that effectively heats up the speaker coils enough to cause a temporary short circuit that kicks in the protect circuit.
2) The output transistors or bias transistors are sensitive to heat and breaking down again causing the protect circuit to kick in.
A few experiments to try:
1) Does the time to shutdown change depending upon the volume level?
2) Is there any background noise coming from the speakers? Listen to a blank tape for example. Is there a hum or any other noise that you would not normally expect?
3) If you have a DC voltmeter, check for any voltage between the speaker lines.
Update this and we'll try to narrow this down.
Dan
Aug 18, 2008 | Audio Players & Recorders
Amp not working properly.............
Mke sure that the tape monitor switch is turned off.
Dan
Apr 09, 2008 | Audio Players & Recorders
Erratic volume on Technics SU-X911 amplifier (Class A)
its the ic that controls the + and - voltage and there are capacitors that have leaked all the caps on that board need changing could be expensive and time consuming but its the age of it . if i was going to do that job £200 plus\
Aug 24, 2007 | Technics SA-DX940
MA Audio Hard Kore HK-898 Car Audio Amplifier Logo
990 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
