SOURCE: Monitor automatically clicks into power saving mode
check the primary settings for your default video card.
SOURCE: Monitor keep going into "sleep" mode
try to reseat the memory modules and restart the computer and computer boots to normal mode/then go to power options in control panel and disable the sleep mode option for the hard disk
SOURCE: Dell PC Power Save Mode
When you first plug it in and turn it on, the monitor will shut itself down with only this little note until it receives a signal from the computer to do something else.
You will have to double check the computer as well, and ensure that it too, is turned on. If this is the case, then your next step is to ensure that the monitor and the computer are talking with each other, that is, you'll have to unplug the monitor from the computer and plug it back in again.
If you do all these things, and you still have this message, then something may be wrong with your video card. At that point, you may have to consider taking it to a professional.
good luck
tony
SOURCE: Dell PC tower will not wake what seems to be power
you have a defective power supply or a bad modem try new power supply if same result try take out the modem last pci slot on the board and your pc will became awake again thanks
SOURCE: when i power on the computer a message appears on
go to the bios setup ang change the settings not to go to power saving mode
