Convergerence Panasonic PT-47WXC43 47 in. Rear Projection Television Problem: Convergerence will not get rid off my ''red ghosting''... Solution by: Abrsvcs (1819 solutions) Itis likely that there are poor solder connections at the convergenceICs. The extra vibration might have been enough to completely break theconnections. If you can
    Genius:
  • 2,920 Answers
Have a shop come out and fix the tv the right way instead of guessing what might be wrong
Posted on Nov 23, 2008
I am getting red ghosting, and can't adjust it. Can you tell me what might be wrong?
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Oct 03, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-51hx41e
This is a convergence output IC problem. convergence board (main Board) would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 26, 2009 | JVC AV-48WP74 48" Rear Projection...
Blue tint ghosting, seems like a convergence problem on my 2003 panasonic rear projection tv pt47wx53. Are their kits available to fix this or how can I fix it myself? Adjusting the convergence does not...
yes you can get the PT47WX49 convergence repair kit at the following link listed under their Panasonic kits category. The kits contain the two Convergence ICs and the feed resistors plus a CD which has the installation instructions. www.tvrepairkits.net
Jun 25, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Pt-47wx53g has red ghost. I tried adjusting convergence but some will not adjust
You have a problem with the convergence output IC's. They need to be replaced. This is a very common problem with all projection tv's as those IC's are high current components.
Jun 10, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red ghost images
Yes there is a repair kit for your model which contains the two Convergence ICs and the 6 feed resistors. The kit alkso has step by step instructions with pictures so you can easily do the repair. Heres the link for the correct kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jun 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Color ghosting?
sounds like it needs the guns aligned...you have to call someione in to do that...they don't tell you that when you buy one of those that after so many hours they need to be re aimed
Oct 09, 2008 | Panasonic PT-47X54 47" Rear Projection...
Panasonic t.v projector
you need to replace both your convergence ICs they are both STK392-110 you can get replacments at the following link with free instructions with pictures.
Aug 02, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic projection tv
turn off the color and see if its still ther if so possible convergence  alignment.
Sep 30, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic pt-47wx53g
You will have two of the STK392-110's in the set so a good idea to replace both. The reason is one of the IC's is dedicated to RED horizontal and vertical and then GREEN horizontal, the other is dedicated to the BLUE horizontal and vertical and then the GREEN vertical. These are the best place to start for ghosting in the colors.
Mar 12, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
