Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Screen flickers, turns on and off
When tested the monitor originally appeared to function correctly. I was turning the contrast up (holding the button) when the screen turned off. When the image came back (a few seconds later) the screen was flickering (like a CRT on a low refresh rate) then started turning off then back on every few seconds.
Upon disassembly of the monitor it became evident it had been repaired previously. Two legs on the transformer have been resoldered, presumably due to the common dry solder joint problem i've read about on this board. The two capacitors (C111, C112) that lead directly to the backlight power ouputs have either been resoldered or replaced. The capacitors currently in place both read "22J 3KV". There doesn't appear to be any dry solder joints present on the board.
  • 153 Answers
Normally this kind of problem needs only the dry soder, cause theres some loose components some where on the main board. Try to resolder any visiual suspicious terminals of components.Try to see carefully if any of the capacitor has any buldgy appearence on top of them. If there is try replacing them.cheers
Posted on Nov 23, 2008
    Scholar:
  • 66 Answers
Hi, My name is Kevin and I may suggest that the inverter be replaced. Usually when you replace the tubes the inverter should be replace also. It is hard to find replacement parts for some of them but they do make universal ones that work with most monitors. Now we need to know if it is bad or the tubes are now bad. The tubes last on an average of 33,000 hours. They are not easy to replace if you have never done this before. Here is a link to the same type of solution. When you get to the tubes they will be black on the ends like a normal florescent bulb if they are bad or hook them ut to the new inverter to see if they light. http://www.fixya.com/support/t859266-koss_kld2700_lcd_tv_no_picture All lcd monitors work somewhat the same , as I can see from your measurements , you seem to now something about electronics so you can try this yourself. It will cost about $50.00 to DIY or $100.00 for someone else.
I have purchased from the site in hong kong and lcd parts.com and they are reliable. You can take the screen apart , on the top and bottom of the LCD you will find encased in a aluminum frame a long cf tube that looks like a long tube florescent light bulb but the thickness of less than a ball point pen refill and averages in lenght of the screen size. They are VERY fragile and does not take much to break in half.....I hope you can get it going again and as always you really feel good when you do it yourself. You learn allot about it . I know purchase only Samsung with the built in LED lights , last longer then the tubes by far . When you tear into the monitor, set up a static work station with a wrist strap and plenty of light , paper, pens, notes and even take step by step photos works well. Good luck and I hope this helped you some.
Kevin
How to get rid of osd lock on screen?
Try turning the monitor off, holding the + and - buttons for brightness and contrast and turn the monitor back on release the buttons.
Next if that dosent work hold the menu button down until the osd unlocked pop up appears.
hope this helps.
Feb 04, 2010 | Computers & Internet
Blank screen - appears to be dead
If the screen is completely black, your screen may indeed be dead. There are a few solutions you can try before throwing in the towel though.
1) Test the monitor on another PC if you can.
2) Make sure the contrast, and brightness aren't turned all the way down.
3) Make sure the graphics card in your PC is functional. You can easily test this by connecting a known working monitor to your computer.
If these steps do not resolve the issue, and your graphics card is in good working order, you indeed have a dead monitor on your hands. It may be cheaper to buy a new monitor, than to have that one serviced.
May 30, 2009 | Sony GDM F520 21" CRT Monitor
Brightness/Contrast Adjustment
try going to the setup screen button left of adjustments
try going to the set up menu on the left of the buttons come down to the slider control just above the information icon then go across to color reset hope this helps regards Jim
Mar 12, 2009 | Samsung SyncMaster 2253BW LCD Monitor
My laptops contrast is low how do i turn it up?
on most laptops there are function keys that will adjust the brightness and the contrast for your display. they are usually the up down left right arrows and you have to hold down FN and then press one of those corresponding keys and it will adjust the levels.
Feb 17, 2009 | Gateway FPD2275W LCD Monitor
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
How to convert this copier from inch to metric system??
SELECTING THE ORIGINAL SIZE
If you loaded a non-standard size* original or the original size was not correctly detected, set the original size manually.
Perform the following steps after placing the document in the document feeder tray or on the document glass.
1 Press the [SPECIAL FUNCTION] key.
The special function
screen will appear.
2 Select "ORIG. SIZE ENTER" from the
menu with the [ ] or [ ] key.
3 Press the [OK] key.
The original size selection
screen will appear.
4 Select the original size with the [ ] or
[ ] key.
The selected original size
is highlighted.
• To select an AB original size, press the [ ] key and
go to step 6.
• If you selected "SIZE INPUT", follow steps 4 through 6
of the procedure in "USING THE BYPASS TRAY TO
COPY A SPECIAL SIZE ORIGINAL" (page 51) to set
the horizontal and vertical dimensions of the original.
5 Press the [OK] key.
You will return to the base
screen and the selected original
size will appear in the original
size display.
Selecting an AB original size
6 Select the original size with the [ ] or
[ ] key.
To return to selection of inch original sizes, press the
[ ] key to return to step 4.
7 Press the [OK] key.
size display.
* Standard sizes:
The following sizes can be detected correctly: 11" x 17", 8-1/2" x 14", 8-1/2" x 11", 8-1/2" x 11"R, 5-1/2" x 8-1/2"
(A3, B4, A4, A4R, A5). If a non-standard size original is placed (including special sizes), the closest standard
size may be displayed, or the original size may not appear.
Note
DUPLEX
SPECIAL FUNCTION
ACC.
DUPLEX SCAN
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GH
PQR
DUPLEX
SPECIAL FUNCTION
DUPLEX SCAN
SPECIAL FUNCTION
SPECIAL MODES
ORIG. SIZE ENTER
PAPER SIZE SET
DISPLAY CONTRAST
GHI
BACK OK
ORIG. SIZE ENTER
11x17
8 x14
81 x11
INCH
ORIG. SIZE ENTER
11x17
8 x14
8 x11
INCH
To cancel an original size selection, press
the [CA] key.
OK
ORIG. SIZE ENTER
A3
B4
A4
AB
OK
Note
Oct 02, 2008 | Sharp AR-207 Copier
LG 700E MONITER britghtness and flicker
trace abl from fbt to video preamp ic.
replace ic if nothing found bad.
Sep 23, 2008 | LG Studioworks 700S 17" CRT Monitor
SDM-P234/B Won't turn on
Follow this procedure to troubleshoot the monitor. NOTE: Since each of these steps represents a possible solution to this issue, check the display function after completing each step. 1. Download and install the latest video drivers for the video card. 2. Disconnect the computer and monitor from any surge protector or power strip and plug it directly into a known working wall outlet. NOTE: If the display returns after completing this step, the problem is isolated to the surge protector or power strip. 3. Ensure the monitor cables are connected correctly. 4. Perform a monitor self-test. 5. Adjust the monitor brightness and contrast levels. NOTE: Refer to the monitor manual or user guide for specific instructions on how to adjust the monitor brightness and contrast levels. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site. 6. If possible, connect and use the monitor with a different computer. NOTE: If the monitor functions properly, then the problem is isolated to the computer to which the monitor was originally connected. 7. Ensure that the keyboard and mouse are connected correctly. 8. Troubleshoot the computer display configurations in Safe Mode. 9. Remove any hardware that has been added to the computer. This includes any added memory, internal or external drives, and any type of adapter card (network, sound, video, USB, etc.) . Let me know what happens. Good Luck, Tim
Feb 16, 2007 | Sony SDM-P234/B 23" LCD Monitor
Screen Blackness (NOT like all the other ones)
Not all inverter problems will be visually apparent. Some capacitors fail with a high ESR and the only way to check that is with an ESR meter. Output transformers can fail subtly and you may have to test them with an ESR or low-ohms meter, but even that may not be definitive. Parts can be shorted or open without showing burns. It could also be a bad lamp / bulb.
Jan 21, 2007 | LG L1951S (Black) 19 in. Flat Panel LCD...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
455 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
