Question about Fuji FinePix S5000 Digital Camera
Camera turns off
My camera turns on fine to playback, but when switched to photography the LCD turns on but goes off immediately. I do hear gears moving upon switching to photography mode.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
CCD sensor is faulty and the sound you hear is camera switching off lens after no signal from CCD block is delivered to the main CPU. CCD has to be replaced and should be done free of charge if the camera is newish and has not been abused ( you bought it with poorely manufactured CCD sensor which should last 15 years ).
Posted on Aug 29, 2007
Fuji Finepix S9600 - Photography mode doesn't work
Sounds like the CCD (main image sensor) is dead. It should be covered under warranty. It doesn't sound like there is anything you've done, or can do to rectify it. Get it in to a Fuji service center with your warranty/receipts.
Sep 27, 2009 | Fuji Finepix S9600 Digital Camera
Nikon D80 - LCD screen goes blank in the mountains
In the mountains, are you subjecting the camera to wide swings of temperature or humidity? These could cause your symptoms.
Sep 04, 2009 | Nikon D80 Digital Camera with 18-135mm...
Camera rapidly beeps 6 times when powered up and immediately turns off!
I HAVE SOLVED THIS!
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking down at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black plastic casing and see 2 PLASTIC GEARS. The top one is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Dec 18, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera wont turn on!!! i hear gears turning
Fuji Technical Support team website is the place to ask for further advice. But if the camera is more than a ear old - replacement is the only remedy.
Jul 01, 2007 | Fuji FinePix E510 Digital Camera
Canon Powershot A75 blurred LCD display
It sounds like the focus element in your lens is not functioning properly. Does the lens retract completely when you turn off the camera? When you push the button does the camera attempt to focus the image? If you do not see any change in the image when you push the button, and do not hear any sound - then your focus motor is either jammed or malfunctioning. David Millier Advance Camera Repair
Feb 13, 2007 | Canon PowerShot A75 Digital Camera
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
158 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
