Question about Toshiba SD-K760 DVD Player
No power when plugged in. On off button stays dark, nothing works
HELP
  • Anonymous Nov 23, 2008
    exactly the same problem as described above. tried to use the unit, but it would not power on. very low usage
    Scholar:
  • 167 Answers
Hello. sound's like a power supply problum. it could be as easy a putting a new fuse in . the first thing is to unplug it from the wall. the open the unit . with a screw driver. and take off the top. of the unit. !!! and look for a fuse.!! to see if it is blowen?.!!! if so .!! replace with the same size of fuse. !!! as what was in it.!!! you find the size on the fuse that you take out.!! of the unit. !!! "dont" use any fuse .!!! only the same size that the fuse say on. !!! replace it .!! put it back together and hook it back up and try it.!!! if not you will have to look for burnt part's on it's mother board. and go from there.!! well 'GOOD LUCK"
Posted on Nov 25, 2008
    New Friend:
  • 99 Answers
I suggest that u check th power supply and the main fuse.
Posted on Nov 23, 2008
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from www.tvrepairworld.com
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
My Olevia 37" LCD HDTV suddenly will not turn on.
power supply board is damaged,only working with standby power
Aug 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Dark screen
reset your monitor settings with deafaults with menu.u see some buton on lcd or monitor.
Dec 29, 2008 | ViewSonic VG900 19" Flat Panel LCD Monitor
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Toshiba SD-K760 DVD Player Logo
215 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
