Question about LG Studioworks 563N 15" CRT Monitor
Display problem in my LG 15'' monitors
I have 2 15" LG colour monitor.
problem for 1st one is -
one day at the time of working with my system suddenly the display in my monitor had gone. When i restarded the system, i found the cpu is running but no display in the monitor is shown whereas the power led status is ok in my monitor. but one vip-vip sound in monitor is located during the system started.
problem for 2nd one is -
same as 1st one but the monitor led light is green but continuously vip-ping. After restart the system 10/12 times suddenly monitor is work.
  • Anonymous Nov 26, 2008
    I am also using the 15" LG monitor & facing the same issue. Earlier the display used to come after some time but now there is no display at all. I get the same whipping sound & a blinking green power LED on the monitor.
    New Friend:
  • 62 Answers
1. cheak the filament path diode,capacitor.
2. there is dry points in power section.
3. replaced 3842 IC supply capacitor 47/100v.
4. LOT sarounds. if in case near to lot one resistor burnt (12k ohm ) change the lot & capacitors,resistor
Posted on Nov 22, 2008
I have a LG flatron L246WHX monitor connected to my laptop, the colour on the screen suddenly is only showing green and purple colours. how do I get it back to normal, is the adjustment done on monitor or...
First, make sure that the cable you are using is plugged in tightly on both ends...if some of the pin connections get loose the colors can go a little funky.
If Cable is tight try another cable. This will eliminate the cable as your problem.
If another cable gives you the same result it is then usually either a problem with the video card in your computer or the monitor itself.
Try plugging the monitor into another computer if you can. If the monitor is OK on another computer, the problem is then probably the video card on your computer. If you have a desktop, it can be replaced usually, or another video card can be added and used if your video card is built into the motherboard.
If all of those fails, it is likely the monitor went bad. Check if it is under warranty to see if they will replace or repair. If not under warranty you may want to replace the monitor at that point.
Mar 23, 2011 | LG 22" FLATRON LCD Monitor
How to change my display setting when my monitor sudden stops working at 1076x768 high resolution
uhh it obiously cant take that resolution maby it can try install a new driver if that does work sorry it can take that high of a resolution
Jan 12, 2011 | LG Studioworks 552V 15" CRT Monitor
Screen colour suddenly gone wrong colour ie dull and blue tinted, not sure what model number but it is a 19inch 1
It sounds like the video cable plugs are not seated properly or bent pins, please check that out first, also try it with another PC to make sure it is not the PC video card problem.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 10, 2010 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Moniter has excess yallow colour
If you can't fix it by the menu, you can try unplugging it from the wall and computer, and wait for a few minutes. If that doesn't work; the monitor is busted and will need to be replaced.
Don't worry, you can pick up a CRT monitor these days, bigger screen size than yours, for real cheap. :)
Nov 30, 2008 | LG Studioworks 563N 15" CRT Monitor
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
LG 17" MONITOR MODEL 700E (COLOUR & SHAPE PROBLEM)
THE PRESCRIBED ARROWS ARE FUNCTIONING WELL FOR INCREASING THE VERTICAL SIGE OF THE DISPLAY OF THE MONITOR.BUT THE HORIZONTAL AROWS WHEN OPERATED ARE NOT ABLE TO INCREASE THE HORIZONTAL DISPLAY OF THE MONITOR TO FULL SIGE. PLEASE GIVE APPROPRIATE SOLUTION.
THANKS
Aug 14, 2008 | LG Studioworks 700S 17" CRT Monitor
My LG CRT monitor does not display any thing when powered on
My LG CRT monitor does not display any thing when its powerd on .
May 21, 2008 | LG Studioworks 563N 15" CRT Monitor
For lg monitor warranty
this monitor having 3 yr warranty
according to the serial no it have warranty till April 2008.
Feb 05, 2008 | Gateway FPD2275W LCD Monitor
Crt screen power not appear
1)check the power supply
2)write in a desktop<properties<settings
3)setting<control pannel<display,appearance
Oct 13, 2007 | LG Studioworks 563N 15" CRT Monitor
LG Studioworks 563N 15" CRT Monitor Logo
161 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
