32 bit,,,i plug up my camera to usb wont load and then try to use memory card to get pictures off and they are in the acer powering technology program but wont load to photo gallery
Has the computer recognized the memory card in the past? If so, try download and reinstalling the memory card driver. Get online
and got to www.google.com In the google search box type: "Acer
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Card Reader drivers. If
after installing the drivers the reader still does not work, you can
purchase a multi format card reader that will plug into you usb port
from Tiger Direct for less than $15. at http://www.tigerdirect.com When
the site comes up just put in the search at the top "SD Card Reader or
XD Card Reader" depending you your type and press GO. You can sort the
returned results by Price Low to High. Do
you have a USB Cable that came with the camera that you can plug into
one of the usb ports on the computer? If so, try that. It's another
way of getting pictures off the camera. Plug the cable on the camera
and into the computer then turn the camera on. The computer will
recognize the camera and install the drivers. You can navigate through
the camera folders just like you do any other device to find the
pictures.
SOURCE: Aspire T690 memory upgrade trouble
Check the Acer web site and make sure U are putting in the correct type of DDR2 ram. Even though they are called DDR2, there are different types, i.e. 5300, 5600, etc.
SOURCE: Acer Aspire T-180 Memory Upgrade question
hello!
You can buy 2- 512 mb DDR2 memory. It should be the same spec with the two current memory.
Memory should be the same specs and capacity, you insert it to your slot 4-1GIG to maximize, in your setting i recommend another 2-512mb bcoz your current memory is 512 mb capacity.
Not advisable to insert diferent capacity or diferent brand memory bcoz it cause damage to the mainboard and memory also.
Up to 4 GB of DDR2 533/667/800 MHz SDRAM (dual-channel support on four DIMMs)
in your case, you can add more 2-512mb memory, DDR 2 refer to your current memory about about this number. 533/667/800 and follow.
melnavz
SOURCE: t 180 desktop acer
Click on following link for audio driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-Audio-Driver-Download-37473.html
Click on following link for Ethernet driver and click on External Mirror 1
http://drivers.softpedia.com/progDownload/Acer-Aspire-T180-LAN-Driver-Download-37475.html
Regards,
Sandeep
SOURCE: when i start my pc acer aspire m1641 after microsift corporation
go into the bios and make sure the USB controller are enabled, save settings and reboot if still same drivers are missing from the operating system, if you haven't got a password boot to windows and plug the keyboard in a different port to re-install the drivers. if you can't, does the computer support ordinary keyboards?
SOURCE: Acer Aspire x3200 vista 64 bit upgraded to windows
post your requst to company
and for some time for your driver
try to search it on related website
