Question about Canon FAX-JX200
Canon fax jx300 code 6000
Removed paper jam now get a check 6000 on the display. When you open the cover the ink cartridge stays on the right side . Any help
appreciated Thanks
  • 2 more comments
  • loly_6666 Jan 07, 2009
    I want adriver for fax-jx200 Please
  • Anonymous Jan 14, 2009
    same problem - cartridge holder does not slide over
  • djamd1950 Apr 10, 2009
    Just bought the canon fax jx 300 Power on and the error code 6000 comes on. The multilingual manual does not mention this code.
  • benito_go893 Jan 08, 2010
    same problem error 6000
  • 59 Answers
SOURCE: check cover/cart
Two possible solutions remove the top cover (Two screws on top after oepening the cartridge door and two push in black nylon screws in either side). and check the activation lever that activates the cover switch is not riding on top of the switch. Second if this happened your toner cartridge make sure this new cartridge is the correct one for the fax and not a HP modified recycled printer cartridge.
Posted on Aug 10, 2007
marsrover
  • 682 Answers
SOURCE: Canon B820
please confirm that no foregin object droped inside like (stapler-pins)--confirm that paper jam switch in good condition and it is lever not broken and can move in free motion.-chek for small pieces of torn paper and clean the paper path.
Posted on Mar 20, 2008
SOURCE: getting CHECK 5100 on a Canon Fax-JX300
FINE CARTRIDGE HOLDER OR PRINT HEAD BLOCKED
Posted on Apr 28, 2008
  • 359 Answers
SOURCE: jx300
What exactly happens when a fax should be coming through and it does not? Does the machine ring and fail to answer, or does it answer, possibly receive, and then not print? Which mode is the machine set for? Are there any error messages on the machine or other LCD message displayed?
Have you verified the telephone line is properly connected so that the machine is able to communicate? Make sure that the machine is able to use the telephone line by using the handset to make a phone call. If this fails, you will know to go through the phone troubleshooting problems, just as you would with any other phone issues.
If the phone line is functional, please reply with more detail re exactly what occurs when a fax should be coming through, e.g. does the fax machine answer the call or let it ring until answered manually? I believe that either there is an issue with the line, or there is an issue with the setup of the mode for receiving, but can not be more specific without more information.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Posted on Aug 16, 2008
THIS FAX CANON JX-200 EVERYTIME CODE 5100 WILL BE COME HOW CAN SOLVE YHE PROBLEM?
Posted on Feb 24, 2009
My Canon ip 2772 Printer does not works. It says Error 6000. What Can i do? there is no paper jam in my printer. Plz Help
Try these:
Solution 1:
  • Verify that the paper tray is correctly set.
  • If any object is placed in front of the machine, remove it.
Solution 2:
  • Search for any small pieces of paper in the printer, or a tiny object.
Solution 3:
  • Power off the printer
  • Wait 5 minute
  • Power on.
Solution 4:
  • Clean the encoder strip with a soft cloth
Solution 4a:
Jun 01, 2015 | Canon Pg40 Ink Cartridge for Fax Jx200,...
Error 6000 Canon Pixma MX925 need help. I've tried unplugging, on-off etc, and nothing so far gets rid of the error message. Any suggestions??
I had this problem it turned out to be a paper jam I could see it sitting under the front rollers behind the ink cartridge transport.
I removed the back panel and then the transport cover exposing the paper. I then gently removed the paper. That sorted it no problems. PIXMA MG7520 Removing jammed paper cassette 1 automatic double sided...
Oct 01, 2013 | Canon PIXMA MP150 All-In-One InkJet...
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has torn...how can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
Error code 6A00 for Canon all in one printer MP830
Error 6A00 has no specific cause and no specific solution/fix. Sometimes, it's cause by Paper Jam, sometimes Waste Ink Tank Full, sometimes Carriage Problem and still many more.
Simplest Trick: Open the front cover, pull the cartridges with the carriage and leave them somewhere on the passage, now close
the cover and turn off the printer, again turn it on. If it's not a fatal error, there'd be no more problem and no more error displays on the screen.
First try this, open the hood (front cover), after the cartridges moved towards the other end/side, look at the other side (the
side where the cartridges were sitting before it moved to the other side). You'll see the Waste Ink Tank Pads (sponge), remove
them and clean them (they should have been soaked with ink, so use a hand-glove). Remove the pads and squeaze or wash and dry them, after they are cleaned and dried, reinstall (re-seat) them. Now power on the printer and check again.
Secondly, (remove the cartridges before you begin) open the doors and look for paper jam or anything inside the passage and through the paper passage. Use a blower to blow all the dust and clear them out. Now turn off the printer and leave it for few minutes while you clean the cartridges, again switch on the printer, install the cartridges. Now see if it's still there or not.
Try turning the printer up-side down, shake it (do this while the machine is off) and again reboot it. Once again check the status.
Push in a photo paper (or similar thicker paper) into the sheet feeder, do this several times and again reboot the printer.
If the problem even after all these are done, let me know.
Good luck.
Thanks for using FixYa.
Jun 05, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Can I refill my Canon Fax JX300 cartridge?
yes you can refill the #40 cartridge mfor the JX300 - but when you put it in you will get a message saying 'ink volume unknown' and it won't do anything and the yellow light on the machine will be blinking. - to solve this problem hold the stop button down till the count of ten and the machine will work normally except you will get no low ink warning
Tony Rae
Inkspot
London, Ontario Canada
May 22, 2009 | Canon Office Equipment & Supplies
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Oct 29, 2008 | Canon imageCLASS D320 Digital Copier
Getting CHECK 5100 on a Canon Fax-JX300
Apr 27, 2008 | Canon FAX-JX200
Canon FAX-JX200 Logo
565 people viewed this question
old marine
old marine
