Question about Canon PowerShot A75 Digital Camera
Usb device not recognised
Up until today my camera worked fine wehen i plugged the usb cable in. now it says that it is not recognised and has malfunctioned. it does this on other computers aswell. is it the camera or the cable or a setting on the computer? thanks
  • kxd13 Feb 01, 2009
    Ditto - same issue. It's not my cable (i use it for another camera without issues) and it's not my PC port...
Yeah, I've had the same problem as well. If anyone knows the fix, please post!
Posted on Nov 08, 2008
Exact same problem here, too !! I have been uploading pictures forever. I can say that this has happened before, about 6 months ago, and for the life of me, I can not remember how I fixed it. I DO KNOW that it wasn't my cable or the connection to the computer or the connection to the camera. Let's hope someone will help us. Meanwhile, if I remember what happened the last time, I will post. Ugh !
Posted on Jan 05, 2007
Unfortunately I don't have a solution for you, but know that you are not alone! I am having the same problem as of three days ago. I have tried multiple computers and even got a new USB cable but the problem continues. Frustrating! Please let me know if you find a solution.
Posted on Jan 01, 2007
My USB cable is playing up!
Usually this thing occurs because of "Not safly removing the Hardware" (Cable, in your Case) or if the cable is just plugged-in and out frequently.
So try to Plug it properly, it shouldn't be loose.
And once this Unrecognition occurs, usually restarting your PC can solve the Problem.
Also check that your connecter and port isn't loose, that makes the cable to Connect/Disconnect.
Regards, Waqar.
Sep 13, 2009 | Sanyo Xacti VPC-T1075 10MP Digital Camera...
FujiFinpix A607. Getting device not recognised when USBconnecting
make sure the software is unstalled via control panel, ad and remove programs, make sure there no mention of finepix now load the software first, then plus in the camera check the usb cable as well
Jun 14, 2009 | Fuji FinePix A607 Digital Camera
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Computer cannot detect camera at all!
Can you use a USB card reader? The canon software is great but it best used for using a method called tethering your camera (when you shoot directly from camera to hard drive)
Jul 15, 2008 | Canon PowerShot G9 Digital Camera
Fine pix s6500 fd camera
first thing i would do would be to make sure you plug the cable first into the usb port with the camera off then turn on the camera, see if it is recognized by the computer. If not the next step is to check your usb driver to make sure it is working. Try some other usb device. If it is recognized then i would make sure you have seated the memory card properly in the camera as well as the cable. I know that sounds dumb but that little usb cable to the camera has to be well seated. You may have to update your driver for the usb port.
May 15, 2008 | Fuji FinePix S6500 Digital Camera
Lexmark Z1380 Printer
ok..you may have blown the drivers..you can find new lexmark drivers for your model and o/s here
Mar 20, 2008 | Lexmark Z1300 InkJet Photo Printer
Photo's won't upload!
Try it on different pc to make sure it's not the camera, if it works on different pc, uninstall all the usb drivers in device manager then reboot
Mar 05, 2008 | Vivitar ViviCam 4345 Digital Camera
Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
Feb 13, 2008 | Cameras
Connecting to PC
First, let's get the obvious/simple things out of the way, just to be thorough :) :
Power off the PC, leave ten seconds, power on again then try it.
Have you tried it with another USB cable
Have you tried it on another USB port on the PC (if you've been using a front port, try a back one & vice-versa - they're often controlled by different chips).
Assuming none of those work, the most likely cause is a corrupted USB driver. To fix this:
* Make sure the camera's USB cable is not plugged into the PC.
* Uninstall the Olympus software (Camedia Master) if you have installed it.
Now delete the C5060 device as follows:
* Go to the Control Panel. Double click on System. Click on the Hardware tab and then click "Device manager".
* Go to the View menu and click "Show hidden devices".
*Scroll to the bottom of the device list and expand the USB list. You will see some USB Mass storage devices.
* Go through the list: double click on one, wait for its properties sheet to open and look at the Location. It will have something like:
Location 0 (C5060Z ).
Hit "Esc" to close the property sheet. If it was the right one, delete it (select it with the mouse and hit Delete). If it was the wrong one, proceed to the next one.
* Close Device manager.
* Reinstall the Olympus software if you are using it.
* Plug the camera's USB cable into the PC as usual. If all goes well, you'll get the "Found new hardware" message and it will proceed to reinstall the driver, following which all should be well.
Oct 14, 2007 | Olympus Camedia C-5050 Zoom Digital Camera
Usb extention lead doesn't work with webcam
So you know the cam is ok and the cable, so you will have to point to the usb port not being able to push enough power through the cable to the camera as it must take a higher voltage than the other cam. Make sure that the other cam software is uninstalled and you have done registry clean in case of conflicts and also try using a different usb port but install the camera with the driver again using the extension in it, aplogies if you did, i am assuming you may have installed the camera directly without the extension cable.
Apr 29, 2007 | Logitech QuickCam Pro 5000 Webcam
Canon PowerShot A75 Digital Camera Logo
103 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
