Check the battery: Make sure the battery is fully charged and properly connected to the scooter. If the battery is low, charge it fully before trying to use the scooter.
Reset the controller: Turn off the scooter and disconnect the battery. Wait for a few minutes, then reconnect the battery and turn on the scooter. This should reset the controller and may fix the issue.
Check the freewheel lever: If the freewheel lever is engaged, the scooter will not move. Make sure the freewheel lever is disengaged before trying to operate the scooter.
Check the throttle: If the throttle is not working properly, the scooter will not move. Make sure the throttle is fully engaged and that there are no obstructions preventing it from moving.
Not familiar with your particular scooter - but I am well versed with electricity. The issue you're seeing is likely a result of a poor connection somewhere. The amount of power (current in amps) required to operate the horn or lights is a small fraction of that needed to run the motor.
You should trace larger sized wires/cables from the motor back as far as you can - ideally to the battery if possible. Remove, thoroughly clean and reconnect each of these cables under each terminal screw - one at a time. This way you'll know any unconnected cable goes on the only terminal that is removed.
At this point, you should have 100% good connections for all high current loads - including the motor and will probably be able to use the scooter. Placing the battery on a slow trickle charger overnight will help ensure that the battery is fully charged - not just enough to operate the horn or lights.
This could be the brake lever is in the wrong position, should be in the drive position. Failing that, it could be the motor brushes need attention or the drive coupling has failed.
Trace the throttle cable from the handle to the(carb or throttle body).Either the cable is broken,it has come off at one end,or the throttle handle or a piece of linkage is broken or loose.(this is a pretty basic problem-you can do it!)
trace the cable to the connection on the motor.check that throttle lever is connected to cable,and lever moves when throttle is turned.cable may have broken.
NashvilleDan, this scooter has 2 12v 10 amp batteries in series, you should read over 24 volts at the charging hub if the batteries are good. I would think that if the scooter sat for over a year you have bad batteries, They can be purchased at battery plus.
