Question about Sony KDF-E42A10 42 in. LCD Television
No video, but with audio Sony LCD 42'' kfd e42a10
Initial Symptoms: Will only turn on first thing in the morning (after overnight tv off). If you turn it off, it will not turn on again. Then in the evening when I com back from work, it will turn on fine again. If I turn it off, it will not turn again. It happens for several weeks.
This week it wont turn on at all but audio is fine. If I turn it on, the green light will blink several times, followed by red blink then it will turn off.
Thank you for your advise and assistance.
circuitcity
  • 137 Answers
SOURCE: KDF-E42A10 connection Issue
Hello JT,
Thanks for the request. I cannot post manufacture software on a public forum like this. Please visit http://www.interactiverepair.com and select service---> request tech support and a tech specialist will upload the software to you with full instruction.
Best regards
circuitcity
Posted on Jul 17, 2008
experttv
  • 203 Answers
SOURCE: 42" sony wega KDF-E42A10
4 blinks is a fan error. I would take the back off and look to see if the fans that are visable are spinning when you try to turn it on. If you see one that is not spinning it needs to be replaced. If all the fans you can see are spining then there may be some fans that are hidden, in this case you will need to be able to use a meter to determine what fan to replace. Let me know what you find!
Tim nolan
Posted on Sep 24, 2008
eagle338
  • 4889 Answers
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
Posted on Dec 24, 2010
Kensolutions
  • 455 Answers
SOURCE: sony 3 lcd rear projection tv hd w/ wega gate.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Posted on Jun 12, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony kdf-e42a10 green light blinking, followed by solid red lamp light - tv will not respond to power button
Follow instructions in owner manual and remove and inspect lamp to see if shattered inside.
Most of these sets have a 2,000 hour life span on the lamp which is customer replaceable.
Posted on Mar 12, 2012
My parents have a Sony KDF-E42A10 42" LCD TV. They have audio, but no video. Screen is black. Do you think they need a bulb replacement?
Yes, if lamp has not been replaced in last 2-3 years then it is lamp problem. If tv does not shut down and its standby light does not blink in red then lamp is cause of problem, replace it to fix tv issue.
Sep 26, 2010 | Sony KDF-E42A10 42 in. LCD Television
Sony 50A10 LCD tv. Turned on tv this morning and
Yeah the fans continue to rotate for at least 2 minutes past shut off time.
Nov 16, 2009 | Sony KDF-E42A10 42 in. LCD Television
No Sound, Black Screen, 42" KDF-e42A10
If your tv is flashing 7 times. Disconect audio module. It is on top of power supply. Turn tv on you will have picture. Conect the audio outout from the rear. To the aux. input of a stereo. Where you night control audio level. Or get a new audio board. Its is very expensive get only the audio amp I. C. The audio. part. No. 1-866-539-11
May 25, 2009 | Sony KDF-E42A10 42 in. LCD Television
Black Screen with sound
Take a look at your lamp in your tv. Your owners manual will tell you how to change it.
May 23, 2009 | Sony KDF-E42A10 42 in. LCD Television
Our Sony KDF-E42A10 42 inch LCD TV has yellow hue
Contact Sony. You need optical block replaced. Class action .Sony may cover this.
Apr 07, 2009 | Sony KDF-E42A10 42 in. LCD Television
I have a Sony KDF-E42A10 42" LCD TV that has probably 100 vert
Its a b-block assy that causes the vertical lines b- block is out
Mar 31, 2009 | Sony KDF-E42A10 42 in. LCD Television
Sony LCD KDF-E42A10 Television
Please count flashes on Sony KDF-E42A10 tv and let me know.
Its error signal and shows problem with particular area in your tv.
Sep 29, 2008 | Sony KDF-E42A10 42 in. LCD Television
SONY MODEL KDF-E42A10
Sony model KDF-E4210 TV works fine for about 20-30 minutes on HMDI video 6. After that, the HD channels scramble (wavy video). I have swapped out and used the component cables and the same thing happens. Time Warner came out to check their box and all checks out.
Coincidentally, this started after I purchased a Wii and go back and forth from Video 2 (wii) to Video 6. Now is happens just on Video 6 after 20-30 minutes. Could this be an issue with the TV?
Oct 29, 2007 | Sony KDF-E42A10 42 in. LCD Television
Sony KDF-E42A10 42 in. LCD Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
