Question about Maytag PAV2300 Top Load Washer
Washer spins slowly & won't drain
I think I may have a sock or something stuck in the drain line, but I can't figure out how to open up the front panel to access everything. Once I do open it, how do I locate and remove the item? If it is not a sock or something stuck, what else could it be? I also have some water leaking under the washer. Thanks.
  • 1 more comment
  • carlos345 Nov 02, 2007
    spins very slow and will not drain,
  • fixall2 Jul 19, 2008
    Had the corigated shim slip out between the pulley and bearing on the pump. Worked it back in place, It lasted a week and then put in a new pump. Now, it won't drain. Just changed the belt. Any new suggestions? Thanks, Mike
  • Anonymous Jul 20, 2008
    I see that another man has reported exactly the same problem I am having I am having on your site. The corrugated shim on the water pump drive pulley is working its way out from its position around between the driveshaft and the drive pulley. I see no way to secure it in its proper place. Is this normally a sign that its time to replace the water pump?
    The other person who reported the same problem on your site said he reseated the corrugated shim and had to replace his pump 1 week later.
    Thanks very much
    JD Rice
  • 625 Answers
Look at the bottom of the front panel. There on either side is a philips head screw. removing these will release the front panel. the upper part may have spring clips to the top. clearly it is nearly impossible for a sock to get stuck in the pump as the water drains out through all them tiny holes in the drum. look for a broken belt. there should be two of them. the motor is in the left front portion of the washer and is spring loaded to push out from the center.
Posted on Aug 20, 2007
Water did not drain
see the causes and fix it. God bless you
If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Sep 22, 2012 | Kenmore HE2 Plus Front Load Washer
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Tub not draining in washer
If it won't drain, something is plugging the drain system. Start from the hose end. Make sure the hose is open at the end. Try lowering the hose to almost floor level. Make sure you have a pail handy. The water from the tub will be higher than the hose end and the blockage might come squirting out. Put the hose back into the sink or drain pipe it was in.
If water comes out of the hose, but the washer still doesn't "drain," turn it on to a point in the cycle where it should be draining (spin cycle). Listen to hear if the pump is running. If it isn't, there might be something caught in the pump, the pump impellers (that push the water through the pump) might be stuck or broken. This will require a service person.
A third thing you can try if you feel really handy, is to figure out how to open the top of the washer. (Do this with the washer unplugged.) This is often a couple of spring clips near the front edge. Push in on these clips with a putty knife or something else thin, while lifting the top. Once you get it open, scoop out the water between the tubs if you want to. Other wise reach in between the tubs and find the drain hole where the water leaves the outer tub. This happened to me once and there was a child's sock in the hole. Pull out the blockage, reassemble the washer, plug it in and see if the pump check works.
Like I said, it's the outer tub, the pump or the drain hose usually. Good luck.
Jun 14, 2012 | Maytag Washing Machines
Kenmore HE2 front load washer that does not drain and spin well. It does drain and spin sometimes though, so nothing is preventing from doing that. The service tech replaced the pump, but he could not fix...
Some how there is debris like socks or something small getting down and blocking your drain plug. take the bottom panel off your machine by removing the 3 (1/4") screws at the very bottom of your washer. once the panel is removed you'll see a 1 1/2" PVC white valve plug. open that by turning it to the left untill open (WARNING ALL THE WATER WILL DRAIN OUT THOUGH THIS PLUG) remove debris and you all set.
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
My washer washes but dosn't drain or final spin
sounds like a sock or something may have become logded in the drain line.
Jul 26, 2009 | Frigidaire ATF6000ES Front Load Washer
GE washer not draining
You should have one. Get down low, and look at the kickplate. You should see screws just below the main front panel of the machine.
best regards, --W/D--
Jul 25, 2009 | GE Washing Machines
Washer doesn't spin or spins slowly.
it could be something stuck between the tub and basket, like a sock. or it could be the clutch worn out.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 18, 2008 | Whirlpool Washing Machines
Ge washer model#wjsr2080t6ww
Sounds like something is stuck in the drain pump, maybe a sock. Remove the front panel by sticking a small screwdriver or putty knife just above the front panel to release 2 clips. Drain pump is located bottom right with 2 hoses connected to it. Drain the machine and remove the hoses. Check for obstructions.
Apr 07, 2008 | Washing Machines
No-spin and noise
ok first it sounds like something is stuck in your drain pump first if you have a shop vac then vac out the water through the drain line then tape the lid shut and lay the washer on its back to service also on the front panel on the inside will be a tech sheet there good luck
Jan 21, 2008 | Kenmore 24032\24036 Top Load Washer
E20 error message
The E20 error code means - not draining It seems more as an issue of a clogged drain line or malfunction pump.
Dec 11, 2006 | Zanussi ZWF1440 Front Load Washer
Maytag PAV2300 Top Load Washer Logo
195 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
