How to conect my laptop to Niko tv ?
I have a NIKO TV -OTP- 20115 ,
I would like to conect my laptop to tv to see movie , how to connect it ?
Thanks.
Steve
    Brigadier General:
  • 6,966 Answers
Initially, it is required to determine what video out is available from your laptop. Most laptops have the standard 15pin VGA out as a secondary video port. Still others have a single yellow RCA for composite video output or an S-video output and some newer ones have DVI and/or HDMI. Thereafter, you need to determine what king of INPUT connection would be acceptable by your TV. Most TVs have the single yellow RCA for composite video input or an S-video input. Some high ends have VGA, component, DVI and/or HDMI. As soon as the common connection point has been established, the appropriate cable has to be sourced. it will also be necessary to determine the maximum screen resolution of the TV so as to set the Display Properties/Screen Resolution of the laptop to match that of the TV. Often to enable the external video/TV, the Fn + F? keys on the laptop must be pressed several times to cycle on LCD display only, LCD + TV, TV only. The F? key on the laptop would be the function key with the smaill monitor icon.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 22, 2008
Need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
May 26, 2009 | Niko OTP-2613W 26 in. LCD Television
Problem:Won't turn on and off with remote or manually.
Mostly likely, it is your power supply. Is it getting hot? Most of them have a thermal protection circuit which will shut them off when they get too hot. You can order a new one off Ebay for about $20 -$40 depending on what voltage and current you need.
http://stores.ebay.com/LCDPAYLESS
Make sure you order the correct plug size too for your TV.
Apr 11, 2009 | Niko OTP-2613W 26 in. LCD Television
NEEDED remote and manual for my Niko OTP-2011R 20 in
Wow, not much support from Niko.
Their website is:
http://www.viewtekcorp.com/ (currently does not load)
Contact Info:
Viewtek Corp.
20957 E. Currier RD, Unit# G
Walnut, CA 91789
Tel: 909-598-6608
Fax: 909-598-6008
E-mail: service@viewtekcorp.com
I would try the company for the replacements and would obviously suggest calling the company (8:30am-5:30pm Pacific Standard) Monday-Friday.
Apr 02, 2009 | Niko OTP-2011R 20 in. LCD EDTV
NIKO 32 in
I have ordered the owners manual for the Niko OTP3211W.
I'll let you know what happens when it arrives.
Dec 31, 2008 | Niko OTP-3211W 32 in. LCD Television
How do you connect a...
If you use RCA cables from the dvd player set your tv to (line) or if your useing coaux cable try ch.3 or ch.4 your dvd might have a switch for 3or4
Dec 24, 2008 | Niko OTP-3211W 32 in. LCD Television
Remote control codes
That is what I'm talking about, not even Niko knows of a code. That is why I had to buy a learning remote like the Sony RM-AX1400.
Apr 06, 2008 | Niko OTP-3211W 32 in. LCD Television
Need Power Supply
usually Lcd tv rated 12volts 3 ampers
but be careful.. check the polarity of ur lcd before plugging it.... some power supply has different polarity. good luck..
Feb 12, 2008 | Niko OTP-2011R 20 in. LCD EDTV
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
