Question about Sony PlayStation Portable (PSP) Console
Hooking up the first playstation
I tried to hook it up to a splitter from the tv and still no results.I need some ideas.
    Problem Solver:
  • 3 Answers
Man u cant do it, buy a psp 2000 series and an av in cable. the old psp's are not capable, i tried for hours. trust me it will not work no matter how hard you try. sorry if i brought u down,but thats the truth!
Posted on Nov 23, 2008
I have a Samsung HDTV and am trying to get Surround Sound for the PS3 Have the Panasonic SA-HT65 system any help
hook the ps3 sound cables to the Panasonic system or get some of the splitters and hook one end to the tv and the other to the sound system, im pretty sure the tv doesn't have an out for the sound so without a couple splitters its either the tv or the sound system
Mar 06, 2010 | Panasonic SC-HT65 System
Our first tv has a booster amplifier on the coaxial cable, i have purchase a new tv and need to know what product i need to us to attached the new tv's coaxial cable too. We have used a splitter box, but...
To have good picture quality you need zero DB (decibels) for one TV without a splitter. You can use and inline amplifier for each individual TV hooked up to the cable input with a output leg connected to each TV. If your house in wired in parallel (one main input hooked up to a splitter with all of the other TV's run off of the splitter) you can use a whole house amplifier hooked up inline between the input line and the splitter. If you house is wired in series (the input goes to the first outlet, then splitter to second outlet and so forth) each splitter knocks your signal levels down 50% each splitter. Amplifier placement depends on how the home is wired and how many TV's are in the home. Splitters can be either balanced (50/50 split) or imbalanced (75/25) etc. On a two way splitter 75% of the signal goes out one leg, while 25% goes out the other (usually for FM transmissions). If you have a three way splitter the signal is divided by the number of output legs. Splitters do go bad as well (sometimes only one leg). You can also buy an amp that is multi- port (which splits the signal and amplifies in one unit/ one input and 2,3,4 outputs). Amplifiers are electric and there is no way that the splitter can interrupt the power that would take all the signal away. If you meant that it drops the signal level so the picture is unacceptable, that's different. If you have another splitter in the house try using that one, the other might be bad. All in all you can purchase most anything you need at a Radio Shack and are very inexpensive. Amps can be purchased in different gains (boost). +10db, etc. I cannot believe that your cable company is giving you such minimal signal that 1. you need an amp?, and 2. that one splitter drops your picture to nothing? Your line extenders (amps for the lines that feed your neighborhood) might have problems or need adjustment by the lazy, cheap, cable co. also. I had problems with my cable company (when I had one) my modem would not stay online. 4 months later, they diagnosed the problem and my drop (RG56 cable line that feeds my home from their tap in the cable box outside) was bad. My friend could stay online and 2 months later comcast adjusted their amps (line extenders) in the neighborhood and then he was fine. I know this is a lot to digest, but I'm just trying to draw a clear picture so you can understand it all. I hope this helps and good luck!
Nov 07, 2009 | Televison & Video
Can not get pip to work
Pip has its own tuner, try getting a cable splitter to split the signal into the tv. If you have digital cable you may need a second cable box to do this. If your cable provider still sends an analog signal the splitter will work.
Jul 10, 2009 | Toshiba 53H71 53 in. Rear Projection...
How to hook up a dvd recorder with HTS6500/37?
Suddenly had this problem. My Phillips is hooked up to TV and to Cable Box. When I inserted a DVD it would return a "no disc" but it would read and play CDs. After a call to Phillips...who said that they had no idea what was going on and I should take it in for was 4 months out of warranty. Repair company said it was not worth the repair costs ($200) so I should try cleaning the lens with a lens cleaning disc. I bought a Maxell. It has a set of little brushes on the bottom of the disc. I inserted it and played track 2 for 20 seconds as instructed and voila! It began reading the DVDs again. I was only out the $10 for the disc cleaner. If you have this problem, try the disc cleaner first as it might be the fix.
Oct 03, 2008 | Philips HTS-6500/37 System
Tuner problem?
This is an indication of a bad ground connection. Since you have replaced the cable and splitter, it suggests an internal grounding problem. If you can solder and can get to the tuner, resolder the ground points within the tuner and update this with the results.
Sep 30, 2008 | Panasonic CT-27E13 27" TV
Hook ups
use a video splitter for the audio and video, or go out of the DVD player in to the DVR, out of the DVR into the TV (WARNING!!!! Trying to hook a DVD player to any recording device may trigger the copyright protection, causing blue flashes, and distorted pictures)
Aug 22, 2008 | Memorex MVD2042 DVD Player
Convertor box and Sony Wega with PIP (2 Tuners) and new Digital DVR/VCR
I wonder if the RF interference from the digital tuner. That box will only allow ouput either through the coax or the AV ports. If you do both you will not get a picture.
If you switch them you have to tell the box what your using for output by going through the setup process.
Is the Zenith 901 converter box for your cable TV.
Aug 17, 2008 | Insignia Digital-to-Analog Converter for...
Where do you hook the microphone into on the playstation 3 i have the drums and 1 quitar hooked up.
It sounds like your PS3 has only two USB ports ( other units with bigger hard drives have 4 USB ports). If this is the case, you can get a USB splitter and hook up your microphone.
Feb 10, 2008 | Video Game Consoles & Games
Tv sound & surround sound
Go to Settings/SoundSettings/AudioOutputSettings/AudioInputConnector or DigitalOut depending on type of input you are using for surround.
Jan 02, 2008 | Sony Playstation 3 (PS3) Console
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Aug 19, 2007 | RCA P52930BL 52" Rear Projection...
Sony PlayStation Portable (PSP) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
