Question about Canon PIXMA IP5200 InkJet Photo Printer
I have a new pixma ip5200 inkjet,never used and it just comes up
As a paper jammed.i followed the quick start guide,but it won't do anything.i removed all the protective materials and tape from the printer.i unhooked the printer and unloaded the program and started over again,but it is still doing the same thing.this was back in febrary.
  • ignat4sure Nov 22, 2008
    it, just the same broblem but i got little misunderstand when it happen.
    i cann't installe my driver.
    Guru:
  • Canon Expert
  • 183 Answers
Dear hemi1223,
It seems that the printer has problem with feeding mechanism. Here are possibilities: some materials block paper end so it does not reach paper cam sensor, paper feed sensor error, broken paper left inside printer and sheet feeder part broken. I suggest you to take your printer to the nearest service center.
Regards,
Source:
Canon Inkjet Printer Forum
Posted on Nov 22, 2008
Canon Pixma iP5200 just started to make some thin green lines on photoprints. Colours otherwise OK. Inks are non Canon but long used and previously OK. Have tried tests, cleaning and deep cleaning with...
Are these lines evenly spaced?. Do they always appear in the same spaces?
When printing try and hold the paper so it comes out completely flat and see if the lines are there.
Repost with this additional info and i will try and help you
Aug 19, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
PAPER JAM PROBLEM
remove power (turn off) machine, and open just to show the roller, and manually turn the roller just guide paper out.
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Paper jamming
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 17, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Why is the orange light on my Canon IP5200 printer keep flashing?
make sure all the catridges are proper and there is no paper jam inside in the printer.
Jan 14, 2010 | Canon PIXMA IP5200 InkJet Photo Printer
Canon Pixma ip5200. Inner cover open
The inner cover is the part where the CD print tray goes. When you look at the front of the printer you should see CANON written above the output paper tray - just like in the picture next to you post. If you can't see the word - just fold up the flap.
Nov 10, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Printer jams. gray foam released in paper path.
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Try this I found it doing a search on your machine, that foam was called a blotter, and it should work without it, good luck
Dec 19, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Printer won't print
Dear amcnabb,
How many times it's blinking? If it related to paper jam problem means there is problem with sheet feeder unit or paper sensor. Please check below link for detail.
Regards,
Source:
Oct 24, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
CD R Tray
A very useful guide can be found on the following link: http://pixma.damnmachine.com/172/2007/04/28/models-ip4200-ip5200-pro9000.html
Jul 21, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA IP5200 InkJet Photo Printer Logo
91 people viewed this question
old marine
old marine
