Question about Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive
Have compaq presario 2500 - computer hangs up, freezes and shuts
Down. When accessing anything to do with computer, ie windows explorer, send a file somewhere, computer hangs up, freezes up or sometimes just shuts the system down.....thoughts?
  • bennysclue Nov 22, 2008
    Not a mechanical issue I believe; as a last resort I ended up doing a complete System restore, which has fixed the problem but I lost all data and am starting over from square one....was hoping to avoid that but such is life with laptops....thanks again anyway.
    Novelist:
    Scholar:
  • 85 Answers
My first thought would be to immediately check the processor fan for dust build up on the heats ink since a pretty common issue with allot of laptops is that a small layer of dust builds up on the heatsink sort of like a thin blanket that prevents the air from cooling the heatsink like it is supposed to and that of course causes the cpu to overheat and one of the first signs of overheating is the whole thing freezing up.. And at first it may just happen when doing something extensive that requires allot of cpu power but after a while as the dust layer gets a little thicker it will happen more frequently and could result in a dead cpu after a while. (I have seen this situation countless times)
only problem is that if there is not an access door (removable piece of plastic) on the bottom that allows direct access to cpu fan and heatsink then you will probably have to take apart the laptop somewhat to be able to see if that is the problem (if you do not feel comfortable taking apart the laptop then I would suggest it in to a shop and having them do it since it shouldn’t cost a fortune since its not like they are replacing the motherboard or anything ) since there is really no way to shine a flash light into the vents and see the dust because the layer of dust builds up on the other side of the fan and usually at the other end of the heat pipe on the fins of the heatsink and is usually impossible to see through the vent. (See picture of this for your model computer that i uploaded to my website here: http://systemonenetworking.com/compaqhs.jpg )
NOTE: if you’re going to be attempting to do the repair yourself try to make note or which screws you remove from where since some of them are different lengths for a reason And be extra careful of ribbon wire connections when separating panels and so on
Posted on Nov 22, 2008
Bios
What's the most current OS I can use to replace Windows 98 on a Compaq Presario 1277 laptop?
You might be able to find a stripped down version of XP or put Windows NT on it. Those are my best guesses. NT will let you use newer versions of some browsers as well. Mostly Explorer
Dec 11, 2012 | HP (158800-001) for Compaq Presario 1246,...
Hi, everytime i connect my External Drive it says i need to format the disk before i can use it... and when the disk is plugged in and i try to open my computer or anything of that sort, Windows explorer...
have you tried turning on pc first and allowing it to boot. and then plugging in the external hdd?........ explorer.exe is basicly your desktop icons an such, and sometimes have probs with devices attached with a different file format.
Jan 01, 2011 | Western Digital My Book Essential 1TB...
Forgot password
Try clearing the CMOS. That might clear the password for you.
Feb 28, 2010 | Compaq Presario-Notebook 700 Series, 2500...
Compaq Presario freezes at Windows XP screen no task manager
Try to reinstall the windows. This is definately going to hlp.
Aug 24, 2009 | Microsoft Windows XP Home Edition with...
I have the same problem
could be a bad driver you have installed
Jul 17, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Taking more time to restat
Slower Startup / shut Down / Restart Speeds are usually due to a highly fragmented hard drive.
Run the disk defragmenter by going to start >>programs>> accessories >> system tools >> disk defragmenter
It may take a very long time depending on the size of your disks and the degree of fragmentation
Alternatively , consider using a paid software solution such as Tuneup Utilities which contains a better defragmenter that does the job quicker.
When the defrags done (may take overnight) , you should notice an increase in speed when starting up , shutting down , restarting , hibernating , launching programs and in Windows Explorer ie. My Documents , my computer etc
Hope this helps
Dec 31, 2008 | Compaq Presario C700T Notebook
Compaq Pressario V2000
more information would be helpful. are you running a program when it freezes. does it shut down randomly ?
Robert
Aug 29, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario 2500
at that xp screen the computer loads all of the drivers and windows components. is is possible that something recently installed was not good or something has become corrupted. reboot the computer and as it is coming up continually tap the f8 key. you will get to the windows advanced options menu. choose the option for last known good configuration. if this doesnt solve your problem you may need to reinstall windows on this computer.
Aug 23, 2008 | Compaq Presario 2100U Notebook
Laptop freezes
"I never shut it off " Hope u r hibernating the laptop.. It seems that ur lap is junked with a lot of registery files and starup files.. so it takes a lot of memory to perform its operations and subsequently it hangs up.. and i hope u have installed norton anti viurs. this antivirus needs a lot of resources. better u install Mcafee. The best thing u can do is to install a fresh copy of windows. this will solve ur problem.. and remember keep the startup items to the min level.
Sep 03, 2007 | HP Compaq Presario V2555US Notebook
Compaq Presario 2100 and 2500 ,NX 9000 Pavilion ZE4000 Ze5000 XT Series Keyboard -AEKT1TPU011 CD-ROM Drive Logo
98 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
