Question about Radio Communications
How do i program mobile phone frequencies into bcd396t
I would like it to scan between 890-960 megahertz how do i do this
Thanks
  • 4 Answers
Enter 890.0 press limit then enter 960.0 press Limit
then press the search push on the arrow or hold button to hold and listen in otherwise you will pick up several signals at once. try it..
Posted on Dec 04, 2008
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
Can you help me program in a frequency of 48.28000 that goes to my local utility dispatch in my BCD396XT scanner?
- With the scanner ON and scanning, press the Hold key.
- enter the frequency, including decimal point (48.28)
- Press E
- Scanner will query "Quick Freq Save?" Press E (Yes) and the frequency is entered.
Bill B
Aug 20, 2010 | Uniden BCD396T Handheld Scanner
My phones don't work they all say
Unusual problem on a new phone. Could possibly be radio frequency interference close by.
Some cordless phones operate on the same frequencies as in-home wireless networks. I believe this is the 2.8 megahertz frequency. The phones and the wireless networks can interfere with each other.
Most newer cordless phones are higher frequency (5.8 megahertz?). Wireless networks shouldn't interfere with those phones, but there could be other things that could (e.g., transformers on power poles).
If the phones are new, you might consider taking them back and getting another model.
Oct 10, 2009 | Uniden Cordless Phone
Handheld scanner/preprogramed frequencies
You sure confused me . . .
My recently purchased BCD396XT came with a mind of its own - not matter what I did, it would only scan the preprogrammed systems in Alaska. That didn't do much for me here in Texas, so I had to beat the thing into submission. First I installed BuTel programming software, then I deleted ALL the factory programming. Finally, I used the software to download and program what I wanted from the database at www.RadioReference.com. The scanner does exactly what I want it to.
Jun 11, 2009 | Uniden BCD396T Handheld Scanner
How to program my uniden bcd 396T?
go to bc tool join, radio reference group one you have both you can import frequencys from radio reference group to bc tool program then upload file to scanner
Jan 25, 2009 | Uniden BCD396T Handheld Scanner
Uniden BCD396T Manual
This may help you:
http://myweb.cableone.net/marksscanners/330/330test.html
de KC2HMZ
Jul 16, 2008 | Uniden BCD396T Handheld Scanner
Looking To Buy A good scanner? Is The BCD396T The way to go?
A good scanner? Hmm... too many to list. But the #1 on my list is a Realistic PRO-2006 gapless frequency scanner. This scanner has no limitations to what it can scan. It scans HF/FM/AM/VHF/UHF/Air/TAC/Marine VHF/GMRS/CB/SSB/USB/LSB/WX. Hell, it even scans the FM and AM bands (the music bands). It's frequency range is up in the 1300 MHz range and is probably the only scanner you'll ever need. If it's too pricey, my second recommendation is a Regency MX4000. The Regency MX4000 is a good little scanner with a 950MHz range. It is not gapless however. It has 20 Memory channels and scans AM/FM/UHF/VHF/Air/Marine VHF/Mobile Phone/WX bands. It may be hard to find one because Regency went out of business a while back, but if you do find one, it may be worth your while.
Best Regards,
Gavin93
Jun 12, 2008 | Uniden BCD396T Handheld Scanner
Programing
Hi, this is from the book.
1. Press Hold. Then enter the channel number
where you want to store a frequency, then press
Func and Pgm. The channel number appears.
2. Use the number keys and to enter the
frequency (including the decimal point) you want
to store.
3. Press E to store the frequency into the channel.
If you need to print a new manual, just go here.
http://www.uniden.com/pdf/BC72XLTom.pdf
or you can read it online also,,I hope this helps you out with your problem,,, Mechanic
Jan 21, 2008 | Uniden BCD396T Handheld Scanner
Radio Communications Logo
125 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
