Question about Motorola Mobility RAZR V3
Hello I not sure whether or not I did the pressing strategy right, but the first time I did I just pressed the center picture lense and the StandBy/Off button and I came on and went back out. Then I pressed the left hand corner bottom of the screen and the StandBy/Off button and It worked for about 5 min. and went back out. Nothing is seeming to work now. Do you have any other tips or just take my phone to a Motorola Technician?
    Brigadier General:
  • 7,752 Answers
You should take it to a mobile tech adn have them fix it for you
Posted on Dec 28, 2008
Rebel 350d - i press button 1/2 way and it auto focuses but wont take pic when presses the rest of the way. every once and a while it will take a pic.any thoughts?
it won't take the picture until the focus is not confirmed (big dot lights up in the lower right side of the viewfinder) even though the button is pressed all the way down.
tamron lenses are notorious for slow (noisy) auto focus, so you have to be patient when focusing and half press repeatedly several times before it locks down, confirmes the focus and takes the picture.
May 17, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Tip
Lumix DMC-TZ5 - Adding Time and Date stamp to photos
  • Make sure you have set the date and time correctly on your camera.
  • View the picture you want to Time stamp, by changing left hand slider to green icon.
  • Press the circular 'Menu/Set' button
  • Press down arrow to get to playback mode in the onscreen menu.
  • Press right arrow to access this menu.
  • Press down arrow until 'text stamp' is highlighted.
  • Press right arrow to select.
  • Choose whether to apply stamp to single or multiple photos
  • Press 'Menu/set' to select photo to stamp.
  • Choose which stamps to add. Date, time, age etc..
  • Press 'Menu/set' again and select the 'Yes' box.
The only problem with this is that it will re-size your photos to about 3m, which can make them grainier if you took them at a higher resolution. Unfortunately there is no other way to time stamp your photos on this camera.
on Feb 26, 2010 | Panasonic Lumix DMC-TZ50 Digital Camera
Screen will not read lense
Sounds like you accidentally pressed the DISP or DISPLAY button on the back. This manually turns the screen on/off to save batteries. Just press it one more time to turn it back on.
Apr 25, 2009 | Canon Cameras
Time and date display
I have the same camera and the only way to do this is to first, Make sure you have set the date and time correctly on your camera. Take a picture or View picture you want date & time stamped. Press the circular 'Menu/Set' button Press down arrow to playback mode Press right arrow on 'text stamp' Choose whether to apply stamp to single or multiple photos Press 'Menu/set' to select photo to stamp. Choose which stamps to add. Date, time, age etc.. Press 'Menu/set' again and select 'Yes' in box. The only problem with this is that it will resize your photos to 3m, which can make them grainier if you took them at a higher res. Gillian
Feb 20, 2009 | Panasonic Lumix DMC-TZ50 Digital Camera
My inside screen will not show anything. i can receive and send calls bu dont know who im calling. ive never dropped it, gotten it wet, or damaged it in any way .help
To save contacts on a z310a that has a broken screen, do the following: 1.From standby, (make sure the backlight is lit up) press the center button once 2. Press down once to go to address book 3. Press center button to enter address book 4. Press RIGHT select button (upper right button with line through it) to select options. 5. Press down FIVE (5) times to go to Advanced 6. Press center button to go into Advanced 7. Press down FIVE (5) times to go to Copy To SmartChip 8. Press LEFT select button to enter 9. Press LEFT select button to select "Copy All" 10. Press LEFT select button to confirm. Wait a couple of minutes to make sure all your contacts were transferred.
Jan 08, 2009 | Sony Z310a Cellular Phone
The pictures on my sansa mp3 8gb
I didn't realize the sansa clip supported pictures - are sure you posted in the right section?
Just giving you a hard time. If you have a Sansa Fuze 8GB:
Looping a Slideshow
1. Press Submenu button while viewing photos.
2. Scroll to Loop and select it.
3. Use the thumbwheel to select Loop on or off.
4. Press the Select button.
5. Press the |<< button to return to previous menu.
Specifying the Slide Duration
1. Press Submenu button while view photos.
2. Scroll to Slide Time and select it.
3. Use the thumbwheel to highlight and select the desired duration (from 2
seconds to 30 seconds).
4. Press the Center button.
5. Press the |<< button to return to the previous menu.
Selecting Slideshow Music
2. Use the thumbwheel to highlight Slideshow Music and select it.
3. Select Current Song (if a song is currently playing) or Music Go List
(plays music from the Go List) then press the Center button.
4. Press the |<< button to return to previous menu.
-Tha Mp3 Doctor
Jan 06, 2009 | SanDisk Sansa Clip MP3 Player
Steps to forward inbox texts to email with white screen problem?
First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
Nov 11, 2008 | Sony Ericsson Z525a Cellular Phone
Setup wizard
First open your phone, then press upper right (-) key to get to menu. press joystick down 2 times, then right 1 time, to get to Settings. Press joystick center select button, press joystick down 9 times to get to Master Reset, press center select button. Joystick down 1 time to get Reset Device, press center select, then press upper left (-) key. This will delete all user settings & data, including pictures, messages, data, sounds, games, contacts etc. The phone will be restarted. If this doesn't fix the problem, you will most likely need to replace the internal wiring harness.(Not a job even I would enjoy!) Hope this helps.
Oct 31, 2008 | Sony Ericsson Z525a Cellular Phone
A red line appears in center of my pictures .
There is a light leak in the CCd .... Service centre is the Solution
Aug 23, 2008 | Olympus EVOLT E-500 Digital Camera
How to send picture msg
Here's how send a picture in a message.
1. Press the Center Select Key
2. Press the Navigation Key to scroll to Messaging, and press the Center Select Key
3. Press the Navigation Key and scroll down to Create Message, and press the Center Select Key
4. Press the Navigation Key and scroll down to New MMS Message, and press the Center Select Key
5. Press the keypad to enter desired text
6. Press Options, by pressing the left soft key
7. Highlight Insert, and press the Center Select Key
8. Highlight Picture, and press the Center Select Key
9. Press the Navigation Key and scroll up or down to the desired picture
10. Press Insert, by pressing the left soft key
11. Press Send To, by pressing the right soft key
12. Press the Navigation Key, and scroll down to desired contact, and Press the Center Select Key
13. Press Send, by pressing the right soft key
You can find this, and other helpful stuff at
this page on the Motorola Support site
Don't forget to rate this solution once you've tried it !
Apr 17, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola Mobility RAZR V3 Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
