Its not even 1 week old. I encountered many problems with N79.
Music Player Hangs, when try to forward track or change track nothing works-Only removing battery helps recovering the phone.
Real Player doesn't show video sometimes.
Tried creating new profile which doesn't even open so that I can't create on. On top of that it hanged and had to remove the battery. Still unable to create a new profile.
Clicked on music player listen songs. The song list failed to start. Again same trick to restart is to remove the battery.
Please suggest me is that software issue or hardware issue. The handset updated recently with latest firmware version, no update available.
Any advice will be appreciated.
In memory card,---put right thing in right profile,ling songs give in sound/sample,photo--images(out side camera profile),avoid 2 use lots of application,because phone memory is low.uninstall unnecessary things.use trusted software.
That might any a problem with memory partition, try to remove external memory and formatted your memory with the handset..
You can Reset your handset by dialling the no *#7870#.., please take the back up of your handset before doing that because it will delete all your data.. than try again. If it doesnot work than you have to get your handset flashed from your handset dealer. Nokia support number: 1-888-NOKIA-2U
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card using the PC. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
Check this link for formatting.
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
hi. i have the same problem. my n79 hangs sometimes when plaing music on hadset. when it hangs just take of the headset and put it back. dont touch the battery. i think nokia will fix this error.
