Copy paste Cannot copy and paste in windows xp sp 2
    Scholar:
  • 162 Answers
1. Type http://djlizard.net/software/Dial-a-fix-v0.60.0.24.zip in internet explorer address bar and hit enter and save the file on your desktop. after that try to open it and run dial-a-fix select all option then close it and restart the computer.
2. Try this:-- Internet Explorer, Tools, Options, Security tab, "Custom Level" button, Misc: "allow cut and paste for files", dot the "allow"
3. Try to run sfc /scannow and restart the computer ( Click on Start> Run> Type sfc /scannow )
remember inbetween the scanning you need to insert the windows XP sp2 Disk.
Posted on Nov 23, 2008
How i can make a bootable Windows CD for my personal use
Create a temporary working folder at the root (top) of the C: drive called "XPSETUP" (without the quotes). Actually, you can name it anything you want and put it anywhere you like, but for ease of explanation, the remainder of the steps below will assume that you have created the XPSETUP folder in the root of drive C:. This C:\XPSETUP folder will be where you will create the CDROM directory structure for your bootable Windows CD.
Copy the entire C:\I386 to C:\XPSETUP. When you have finished, you will have C:\XPSETUP\I386. Notice that I said "copy", not "move". Do NOT drag and drop the I386 folder into the XPSETUP directory. If you do so, you may end up moving it into the XPSETUP folder (depending on where you created the XPSETUP folder). It is important to work from a copy of the I386 directory so that if you make mistakes, you can simply go back and start all over again. If you move the directory or drag and drop it, and you make a mistake, your mistake will be permanent. So once again, COPY the entire I386 folder to XPSETUP. It may take a while for the copy operation to complete, but it's safer this way.
If you're not sure how to copy, follow the following procedure: Highlight the I386 folder using Windows Explorer. Right-click the folder and select "Copy". Then open the XPSETUP folder. The folder should be empty at the moment. Right click the empty space in the window and click "Paste". A very lengthy copy procedure will take place.
To verify that you have copied the folder and not moved it, return to the top of C: and check that the I386 folder is still there and that the original files in that folder are still there.
Create an ASCII text file with only the word "Windows " (without the quotes and including the final space after the word "Windows") in it, followed by a new line. To do this, open up Notepad. Notepad can be found in your Start menu -> Programs -> Accessories -> Notepad. Type the word "Windows" without the quotes and following my case exactly (that is, "W" is a capital letter and the rest are in small letters). Then type one additional space. Finally, hit the ENTER key. Do not add anything else to this file. Do not change anything - for example, do not type everything in capital letters or anything like that. The contents of the file must be exactly as I said, or Windows setup will issue an error message.
Save the file with the filename "WIN51" (include the quotes so that Notepad will not add a ".txt" extension behind your back) in C:\XPSETUP. Again, the filename's spelling and case must be exactly like mine.
If your PC or laptop originally came with XP Home, make a copy of the file you just created and call it "WIN51IC". If you are using XP Home Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IC" and "WIN51IC.SP1". If you are using XP Home Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IC", "WIN51IC.SP1" and "WIN51IC.SP2". All the copies of the files should be in C:\XPSETUP.
If your PC or laptop originally came with XP Professional, make a copy of the file you just created and call it "WIN51IP". If you are using XP Professional Service Pack 1 (SP 1), make two copies of the file and call them "WIN51IP" and "WIN51IP.SP1". If you are using XP Professional Service Pack 2 (SP 2), make three copies of the file and call them "WIN51IP", "WIN51IP.SP1" and "WIN51IP.SP2". All the copies of the files should be in C:\XPSETUP.
Note carefully what I said above. You may be running XP SP 2 now, but if your PC came with XP SP 1, you should create the files for XP SP 1. There is an exception to this. If your PC or laptop came with XP or XP SP 1, but you want your Windows install CD to install XP SP 2, create the WIN51 files needed for SP 2 and follow the procedure for slipstreaming Windows service pack 2 (SP 2) into the Windows setup CDROM given in the next step.
If your PC or laptop came originally with XP or XP SP 1 (service pack 1) but you want your Windows setup disk to install XP SP 2, do the following. Otherwise, skip to the next step.
Note that even if you have since updated your computer to SP 2, you will still need to do this step if you want your setup CD to install Windows XP Service Pack 2. The reason is that updating your running Windows system does not automatically update the I386 directory. Your I386 directory still contains the Windows setup files belonging to whatever version of Windows you had when you first bought your PC/laptop.
Download Windows XP service pack 2 from http://www.microsoft.com/downloads/details.aspx?FamilyId=049C9DBE-3B8E-4F30-8245-9E368D3CDB5A&displaylang=en Save it anywhere you like except in the C:\XPSETUP folder. For the purpose of this tutorial, I will assume you saved it as C:\XPSP2.EXE, that is, in the root folder with the filename "XPSP2.EXE".
Important: if you did not configure Windows to show you the full filename you should probably do so before changing the name of the file. Otherwise, you may be inadvertently saving the file as "XPSP2.EXE.EXE" without your knowing. (That is, you see the filename as "XPSP2.EXE" in Windows Explorer but it's actually "XPSP2.EXE.EXE".)
You will need to update the C:\XPSETUP\I386 folder to contain the updated SP 2 files. As a side benefit, the service pack 2 updater will also create a few files (including setup.exe) in the C:\XPSETUP folder. This process of integrating the service pack files into the original XP or XP SP 1 is known as "slipstreaming".
To slipstream SP 2, first open up a command prompt. To do this, click the Start menu, select the Run menu item, and enter the words "cmd". Click the OK button. A black command prompt window will open.
Enter the following line into the window and press the ENTER key.
C:\XPSP2.EXE /integrate:C:\XPSETUP
After the program finishes, you can close the command prompt window. If you look into your XPSETUP folder, you will notice a few new files there.
At this point, the C:\XPSETUP directory contains all the files that will be copied to your Windows Setup CDROM. Don't worry if the directory does not contain files like "setup.exe" which you see on the retail CDROMs. You won't need it for a fresh install from the bootable CDROM. Note: You will only have "setup.exe" if you had to slipstream Service Pack 2 as mentioned earlier. The Service Pack 2 slipstreamer creates setup.exe for you.
Now open the wxp10.zip file that you downloaded earlier. Simply doubleclicking it in Windows explorer should do the trick. Go into the cds directory and into wxphome (or wxppro; it doesn't matter which) directory, followed by the files directory. Drag the "w2ksect.bin" file into C:\ (the root directory/folder of drive C:). Don't get creative and place it in some other directory. If you do that, ImgBurn will not be able to find c:\w2ksect.bin later.
You could do all that OR simply download an XP LIVE DVD.. This will  bootup from DVD and work without using/installing to the Hard Drive.
here is the torrent DL link No torrent?  Here > http://www.utorrent.com/
DL and install.. then click on torrent link and it will DL.
http://thepiratebay.org/torrent/3820108/Windows_XP_Live_Edition(Run_Windows_from_CD)
here is a link how to make it.
http://www.intowindows.com/how-to-create-live-usbcddvd-of-vistaxp/
Feb 01, 2010 | Microsoft Windows XP Professional SP2
Licence key of windows xp SP3
If you own a license for XP, the SP is free to use. If your copy is not legal, it probably will not work anyway.
Dec 26, 2009 | Microsoft Windows XP Professional With...
Windows sp counterfeiting problem
I had a friend who had a copy of xp, said the same thing.
You have a copy of xp that has been registered with microsoft already.
time to buy a copy.
never good to get pirated copies of any software, esp operating systems.
good luck!
May 20, 2009 | Microsoft Windows XP Professional
Boot DVD
you dont need to slipstream the disc with SP 2 or SP 3 but if you want to you can following this guide :
Guide on how to slipstream windows xp with a service pack of your choice
If you get stuck let me know
But basically you create 2 folders on your C drive or on your desktop call one xp disc and the other one service pack
copy everything from the xp disc into the xp disc folder and then download and install iso buster ( download link )
And extract the img file as per the guide and then follow the burning instructions with regards to adding the img file using nero or a burning application. If you dont have nero and want to know how to use the img to make it bootable post back with what burning software you have and what version it is and I will find and post back with a relevant guide
Apr 08, 2009 | HP LightScribe dvd640i (DVD640I)...
Have Windows XP, Home Edition. Cannot install Service Patch 3,
Beethoven 9 is not part of the service pack. Go to microsoft and download the service pack as is. If you don't have a fully registeredwindows program, you will have problems until you register it. I've downloaded all service packs and updates for the past 7 years on different levels of windows without any problems. You must have them registered to prove you have an authentic purchased program, not something copied from someone elses setup disks.
Jan 03, 2009 | Microsoft Windows XP Home Edition
Sound solution plz
goto control panel switch to classic view , double click add remove programs , then when the list comes up look for service pack2 and remove , then restart computer
Oct 25, 2008 | ASUS P5VD2-MX SE Motherboard
Pinnacle studio 11 will not install on my windows xp. I have service pack 1,2 and 3 on here. Yet it says when I go to install it , that my comp does not have service pack 2 and will not install. I think sp...
May 12th, 2008: Some customers reported problems installing Studio Plus version 11 UPGRADE (11.0) or Studio version 11 Standard (11.0) on systems with Windows XP Service Pack 3 was already installed (a message asking for Windows XP Service Pack 2 is displayed). Pinnacle is investigating this problem.
We can offer you the following workaround:
  • Copy all the content of the Installation DVD of Studio version 11 to your hard disk in a new folder.
  • Download http://cdn.pinnaclesys.com/SupportFiles/Studio11/WelcomeSP3.exe
  • Copy the file WelcomeSP3.exe to the root of the directory where the Installation DVD was copy
  • Double-click on WelcomeSP3.exe to launch it. It will take few seconds and then the Studio version 11 installation will start.
Aug 28, 2008 | Computers & Internet
Event repetition, as if key stuck
I think, you have a problem whit keyboard, may be Ctrl key is failed or is broken
Jul 28, 2008 | Toshiba Satellite R10-S802TD Tablet PC
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
