Question about Bugaboo Frog - Aubergine Stroller
Bugaboo frog stroller- wheel put on wrong way
I put the small wheels on the wrong way- how do I get them out without breaking them?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Try www.buggypitstop.co.uk see if they can help you
Posted on Feb 12, 2010
I put wheel in wrong on my bugaboo frog
You need to compress the two lock tabs. This can be done with two large screwdrivers, Slide the flat blade of each driver down between the tab and the side wall of the wheel mount. Twist each driver to push the tabs in and get someone to pull the wheel out. I found a piece of copper pipe I use it's just the right size to slide over the wheels top and push the tabs in.
Jan 26, 2011 | Bugaboo Frog Stroller
My son put the small wheels in backwards. is
yes you can remove the wheel by pressing very hard at the top of the wheel or by using a screw drive to push it in. it's not easy but it can be done. or go to www.buggypitstop.co.uk they repair and service bugaboos
Nov 15, 2009 | Bugaboo Frog Stroller
I put the small wheel on my Bugaboo Frog the wrong way
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 22, 2009 | Bugaboo Frog - Aubergine Stroller
Bugaboo frog and wheeled board not fitting??
Had exactly same experience today. I emailed Bugaboo (via website) and got a reply the same day.
I attached the clips the wrong way round. The picture in the manual is not very clear....The little 'roofs' have to face each other and than you are able to push the clips further over the axle. The slot of the clip fits over where the small wheels comes in on the bar.
Hope this helps.
Jul 26, 2009 | Bugaboo Frog Stroller
Remove the swivel wheels from the bugaboo frog
should be a small metal circle you push in and then pull the wheel off . probably in the back
Jul 07, 2009 | Bugaboo Frog Stroller
Put wheels on wrong and cant get out, anyone out there because i am lost now...
I had the same problem when I first assembled my frog. There is a small lever inside the cap, so turn the stroller over and look in the cap with a flashlight. Poke the lever with a chopstick and the wheel will pop right out.
Jun 06, 2009 | Bugaboo Frog Stroller
Bugaboo frog stroller- front small wheels put on wrong way. how do I get them out without breaking them?
get flash light and butter knife... shine light through back of where you have your wheels... use knife to press tab back and pull on wheel.
Jun 03, 2009 | Bugaboo Frog - Aubergine Stroller
Need to fix a Bugaboo Frog wheel
just order new wheels from bugaboo. They cost about $30 bucks each or contact a local retailer to order you some wheels.
Mar 30, 2009 | Bugaboo Frog Stroller
Bugaboo Frog Stroller (Folds on it's own)
Don't worry, this is normal. Once you lock the seat into place, the front bar stays put, even if you hop a curb.
Mar 23, 2008 | Bugaboo Baby Gear
Bubaboo Frog Tilt Wheel
Hello bugabooownr:
I have seen this problem before. If the wheel was accidentally crushed or bent while still on the stroller, it may have become bent. This has also occurred while checked on a plane. If the stroller is still under 2 years old, bugaboo will usually replace the piece. If not, most bugaboo retailers sell replacement wheels. You can contact bugaboo here: bugaboo.com
Hope this helps:
StrollerInfo
www.StrollerInfo.com
Oct 10, 2007 | Bugaboo Frog Stroller
Bugaboo Frog - Aubergine Stroller Logo
173 people viewed this question
Top Bugaboo Baby Gear Experts
Jennifer Rock
Jennifer Rock
J.D. Browning
J.D. Browning
Jerry Greenberg
Jerry Greenberg
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
