Question about Kenwood Audio Players & Recorders
Kenwood KR-V8090 won't turn on.Makes clicking noise when stand by is pressed. Robin
5 Suggested Answers
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
HomePlicity
  • 41 Answers
SOURCE: do not hear the second click on speaker relay on
I will assume no audio is coming out of your speakers.
When the reeciver starts up It looks at the load (resistance) of the speakers attached to see if it is reasonable. If It appears there are no shorts in the speakers then the speaker relay will close (second click) and send signal to your speakers. If there is no second click then either the the reciver is detecting a problem with speakers or cables or the detecting circuit has failed. I would start by disconecting all speakers then start the receiver up. If your not getting a second click after about 4 or 5 seconds then the receiver will need service. If it does click then shut receiver off, and hook up one speaker at a time, then re-start receiver. If one speaker suddenly makes the system fail then you have found your problem. If you have a Volt/Ohm meter, set it to resistance(Ohms) and measure each speaker. Anything Under 4 ohms will be a problem.
Good Luck
Posted on Apr 01, 2010
  • 222 Answers
SOURCE: kenwood kr 3600 volume potentiometer is faulty
try google and it will give you some local electonic stores
Posted on Jun 08, 2010
  • 27 Answers
SOURCE: Will not turn on, makes a clicking noise
The clicking generally means that the relay is trying to close but for some reason cannot.Usually, (but not always) this indicates a problem in the power supply such as a blown voltage regulator or a zener diode. This is not an easy fix and not for the faint of heart. If you feel up to it, at least try to locate a circuit diagram or even better a repair manual. I like Onkyo receivers. They are generally quite reliable and fixable.
Posted on Jun 12, 2010
I can't operate my kenwood KR-A4070 receiver manually anymore, it only operates with factory remote. When it was new, I could manually press the various function button's..such as power-tuner-etc., an
Only a service person can help now. Likely you have a connection loose, a buldged cap or maybe just a transistor with a cold solder joint. Not being able to see it makes it hard to tell.
Jan 21, 2015 | Kenwood Audio Players & Recorders
My Kenwood KR-v8050 reciever will turn on, but will not go out of stand by mode, the visual screen also is not working, what am I looking at to fix this?
Sounds like either the main power fuse is blown,or the power transformer is bad. If the fuse is blown, probably means the amp is shorted.
Dec 31, 2012 | Audio Players & Recorders
Kenwood kr-720 service manual
Hi Vanpost941,
You can download the manual in pdf by clicking here. or here.
Hope this helps.Thanks!
Please rate this answer.
Nov 24, 2011 | Audio Players & Recorders
Can the Kenwood KR-4600 connect to an ipod?
Hi,yes you can connect Kenwood KR-4600 to an ipod.
Instruction..
You will need an coolken_9.jpgRCA cable .
Connect the RCA (red and black to the input of the Kenwood KR-4600...You have options of inputs to use..
Either input at the back of the Kenwood KR-4600,or tape A and tape B..which ever you wan to use..
After connecting the red and black RCA to Kenwood KR-4600, then connect the other jack end to the ipod, and go the front of the Kenwood KR-4600 to activate the input selection knob to the desired input being selected at the back of the Kenwood KR-4600..
And don't forget to turn on the volume of the Kenwood KR-4600 and also the iPod volume..
And after that your done..
Good luck to you..
Aug 10, 2011 | Kenwood Audio Players & Recorders
Release excellorator makes clicking noise turn
Sounds like your thinking in the right area. Up on stands or hoist look for ripped boot, and/or movement at joint.
Jul 08, 2009 | 1996 Toyota Camry
I have a Kenwood KR-A4010 Am/Fm Stereo Receiver. Every five seconds the sound fades in and out. Can anyone find a solution to this problem?
Something in the unit is smoked and potentially dangerous. Get that puppy down to a repair shop. Don't leave it unattended if you turn it on. Got a fire extinguisher handy?
Apr 28, 2009 | Audio Players & Recorders
Problem with playing my Kenwood KR-X1000
Nov 19, 2007 | Kenwood KR-X1000
337 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
