Question about Dayton Exhaust Blower to vent your grow room or draw heat away from your lamp 465 CFM: Exhaust ... Kitchen Hood
Fan motor my fan in the comm kithen does not turn on the model is 4c400c phase 1 dia 13 1/2 115 volts 8.5 amps @ 115volts the electiction said the motor sized
2 Suggested Answers
SOURCE: How do you wire a dayton electric unit heater?
tengo un motor dayton y nesesito darle un mantenimiento me podrian fasilitar un manual de ma
Posted on Jun 18, 2012
How many amps in the Vision Fitness T9500 HRT Treadmill
it is a 3 horsepower motor, but no amperage specified. The review does say this model has drawbacks.
Vision T9600 HRT Comfort Treadmill review
However, I found this, so 23 to 28 amps based on a 3HP motor.
Note: the following table contains approximate full-load currents for motors of various types, speeds, and frequencies. Variations of ±10% may be expected.
Hp. of
Motor
Current - Full-Load (Amperes)
Direct-current Motors
Single-phase Motors
115
volt
230
volt
550
volt
110
volt
220
volt
¼
4.8
2.4
½
4.5
2.3
7
3.5
¾
6.5
3.3
1.4
9.4
4.7
4.2
1.7
11
5.5
1 ½
12.5
6.3
2.6
15.2
7.6
8.3
3.4
20
10
12.3
5.0
28
14
Oct 06, 2015 | Vision Fitness Exercise & Fitness
Lights 3, 4 and 8 come on and washer won't function
GWL11 (Phase 6 model)
(Lights 3.4.& 8 = 00110001) Phase 2 to 6 - Cold Valve Fault
The Motor Controller has measured a voltage from the valve diagnostic circuit that indicates the
cold valve is faulty. The most likely cause is that the valve harness has not been connected correctly. OR the 24 volt cold valve internal winding has open circuited. Check resistance of 64 ohms across terminals
Jan 12, 2014 | Fisher and Paykel GWL11 Top Load Washer
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
I need to wire up a baldor 3 phase motor 208-230/480 15hp and dont have the wiring diagram to know what wire is what or where to hook it to?
Hi Casey, I'm an electrician and can help you with this problem.
First, a disclaimer. Without the catalog number of the motor you have, or a wiring diagram for it, no one can tell you how to wire this motor with any certainty. With that said...
Nearly all single speed 3 phase motors have 9 leads (numbered 1 thru 9) and can be wired for either "high" or "low" voltage. Most of the time, high is 480 volts and low is 208/240 volts. Given that you posted the amperage as "41-38 / 19", I am 99% confident that 41 amps is at 208 volts, 38 amps is at 240 volts and 19 amps is 480 volts. Further below is the way to wire unless the motor manufacturer or name plate indicates differently. You will need to determine the voltage of the appliance this is going to be installed into. You should be able to find this on a name plate of the appliance - but it may provide a dual voltage spec here, too. If this is the case, you will need to *carefully* measure the voltage with a meter, or find out the voltage of the electric panel that feeds the appliance.
Once you have learned the incoming voltage, you will connect the motor as such when L1, L2 and L3 are the line voltage supply wires and wires 1 thru 9 match the numbers on the nine wires from the motor.
208/240 or "Low" volts:
Motor leads 4, 5 & 6 connected together and wirenut.
Motor leads 1 & 7 to L1 and wirenut.;
Motor leads 2 & 8 to L2 and and wirenut and lastly,
Motor leads 3 & 9 to L3 and wirenut.
480 or "High" volts:
Motor lead 1 to L1 and wirenut,
Motor lead 2 to L2 and wirenut,
Motor lead 3 to L3 and wirenut,
Motor leads 4 to 7 and wirenut,
Motor leads 5 to 8 and wirenut and lastly,
Motor leads 6 to 9 and wirenut.
The motor should be operated briefly or "jogged" to determine the direction the motor turns. If the motor rotation needs to be changed, simply swap any two "L" wires (swap L1 and L2, or L1 and L3, or L2 and L3). Test once more to verify rotation and when correct close the wiring compartment and complete the installation. Swapping the L wires will likely be much quicker and easier to do at the magnetic contactor instead of the the motor's wiring compartment. Either location is acceptable.
You should try to obtain the name plate data for this motor - if at all possible to to make sure of the voltage and wiring method. I hope this helps & good luck!
May 13, 2012 | Gb Electrical 100 Amp GE Load Center
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Have a 3 phase compressor model vr5-8 want to know if it can be converted to single phase 230 volt and how
A 3phase motor cannot be rewired to run on single phase power. You need a phase converter. A 3-phase motor will only run on 3-phase power, and a phase converter will convert single phase power to 3 phase. Just google phase converter. There are two basic types, electronic and rotary. The rotary type are more powerful and efficient, but lot's more expensive than the electronic ones. Your only other option is to replace the motor with a single phase motor. Good luck.
May 17, 2011 | Garden
I have an Ingersoll Rand Type 30 air compressor. Model #234. I was given this unit because the motor had gone bad. I would like to replace the motor and use it but I was not given the bad motor with the...
One dealer for your model compressor is Northern. They are very good at replacement parts. If you do not have 3 phase power, you could shop around for 5 to 7 hp 220 v motor making sure that the motor mount will align with your plate. Pully size depends on dia. of pulley on the pump. Most pumps turn between 550 min to 1100 rpm depending on the power available and cfm requirements. Most motors turn at 1725 rpm so for example if your compressor has a 14 in. pulley then you motor will need a 5 in. pulley to turn it about 620 rpm. The larger the pulley at the motor the higher cfm produced but more amps used. Motor speed x pulley dia. divided by compressor pulley dia. To obtain more efficiency and highest cfm you will need 3 phase. Good place to see motors and two piece pulley combnations is www.grainger.com. Good luck
Sep 25, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Will #14 be okay for 1/3 hp 115 volts about 120 feet
It depends on how many amps the motor is. #14 wire will handle up to 7 amps at 100 feet. If it is less than 7 amps it should be okay. If the wire gets very warm after running then you may have to go with #12.
May 07, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
Goodman 3 ton outside unit fan not blowing
Motor, wiring and/or capacitor. If the sticker on the side of the motor isn't burned off you can get the motor info off that. Model numbers from the motor do little for locating the motor but my help. Best thing to do is get the AC motor specs and look up online (cheapest) or go to a motor shop. The specs you need would be as follows.
Horsepower-Such as 1/4 or 1/3
Voltage-Most likely 240/1 (240vac single phase)
Rotation-CW/CCW looking at the shaft end of the motor
Amps
Frame size
Jul 10, 2009 | Goodman CKL60AR60 Air Conditioner
Kitchen Ranges Logo
57 people viewed this question
Top Dayton Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Dayton Kitchen Range Expert? Answer questions, earn points and help others
