Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Network connections Ohms, i have my crossover cable that you said i needed. what are the next steps?
  • 1 more comment
  • gaffney Nov 22, 2008
    i ping the printer ip address and it still didn't work. the message says "Request timed out"
  • gaffney Nov 24, 2008
    i ping and received (no loss). what should i try next? should i try a hub or router from pc to printer?
    I have a router. Is it possible for me to connect the printer and/or pc through the router in order for the printer to work?
  • Konica Minolta Master
  • 1,879 Answers
Just woke up :) day time here (3pm)
>connect the crossover cable to both printer and computer.
>we already set (but check) the IP address of the equipments. the first 3 set of numbers must be identical and the last set must not. example (computer ) (printer).
>ping the printer
- check the usual (drivers etc)
- run Pagescope Network Setup again.
>i might not be available at a later time (freelancing) but once i'm done i'll contact you asap and we'll do a screen sharing session (prepared one for you).
Posted on Nov 22, 2008
  • monk3ybidzness
    monk3ybidzness Nov 23, 2008
    Try to ping the computer's loopback address ->
    If you get 4 replies (no loss), computer's ethernet is ok. As it worked before via direct pc to printer direct ethernet connection, I'm concerned with the printer's ethernet port. And you already changed ethernet cable (regular and crosscable).
    Standard network setup is the printer to be connected to a router/gateway or a hub, not a good option for troubleshooting if you have to buy the mentioned equipment but better for us if you can borrow one. Got to mention that the printer's network settings requires you to key-in a Gateway address which make the printer look for it for network communication. View this documentation for your reference about network setup ->
    As I checked all documentation Minolta's site have, no in-depth networking information can be found (probably their tech support have access to those information) at 1
    Update me.
I want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
Connect two computers using a crossover cable
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
Hello Brian
Using Xbox Live on Dial up Modem would be a big pain, still listing the steps for you, hope you have a stable connection to successfully connect
Required Items
- Windows ME, XP, Vista
- PC with dial-up connection working
- Ethernet Cable (RJ45) cable or CROSSOVER CABLE
- Xbox 360
Let's Get Started
1. First connect the Xbox 360 and the PC using the Ethernet cable.
2. Double Click your Dial-up Network connection and wait for it to connect.
3. Choose "Start Menu" and then choose "Settings" then "Control Panel".
4. Select "Network and Internet Connections".
5. Open the "Network Setup Wizard" and then press "Next".
6. On the next screen Ignore the checklist and press "Next" again.
7. Select "This Computer connects directly to the internet." and press "Next".
8. Now Select your dial-up internet connection as your default connection to the Internet and press "Next".
9. Select "Local Area Connection" as your private connection and leave all other areas untouched and click "Next".
10. On the Workgroup screen leave all settings alone and click the "Next" button.
11. On the next screen Turn on "File and Printer Sharing" if you want to share your files, mp3's, divx files with your xbox 360 and click "Next".
12. Now review the settings and click "Next" to apply the changes.
13. You do not need to run the Network Setup Wizard on any other pc's so just click "Next" and continue.
Now that the wizard has completed you may need to reboot your PC and dial your internet connection again.
Xbox 360 Setup
Now we have configured your PC to share its internet connection and files to your Xbox 360 we need to configure the Xbox 360.
(Steps for old Xbox 360 Dashboard, in case you do not have NXE dashboard)
1. Go to the "Xbox 360 Dashboard".
2. Select the "System" Blade.
3. Select the "Network Settings" Option
4. Now choose "Test Xbox LIVE Connection".
Your Xbox 360 will now attempt to contact your home network. It will check to make sure it can assign itself a IP ADDRESS from your PC and then it will also check DNS server information and XBOX LIVE.
let me know if this helps
Nov 25, 2009 | Microsoft Xbox 360 Console
How do i get connected to another local computer with wire
you need either a "crossover" cable or both plugged into an ethernet switch, with network settings the same but i.p. addresses off by 1 digit. eg. on computer "a" and on computer "b".
Oct 25, 2009 | Computers & Internet
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
How to connect windows xp and vista by lan using crossover cabel please post full steps
Here are the steps to connect two PCs using a lan cable (crossover)--
1. Be sure that both computers are logged in to Windows.
2. Connect each end of the cat5 crossover cables in to the network cards of each computer.
3. Bootup both computers and sign them both on to Windows.
4. In order for both PC's to be able to communicate together, the Ethernet adapters will need to be configured with a static IP address and a common Subnet mask. As an example, assign one PC an IP address of and assign the second PC an IP address of Both machines should use the Subnet mask Here's how to configure your Network Card: Go to Start>> Control Panel>> Network Connections>> Right click your Local Area Connection and select Properties. Scroll the list for the entry titled: Internet Protocol (TCP/IP). Click the entry and select Properties. Under the General tab, tick the box titled: Use the following IP address. Enter the IP address and Subnet mask that you would like to use. Repeat the steps above for the second computer system.
5. Be sure that both PC's have a common workgroup name of 15 characters or less. Here's how: Go to Start>> Control Panel>>System. Select the Computer Name tab. Click the Change button. Change the Workgroup name. Repeat these instructions on the second computer ensuring that both computers are named exactly the same.
6. Reboot both computer systems.
7. Next, open a command prompt on one of the computers by going to Start>>Run. Type in: command [Enter] or click OK.
8. Type: ping (if you are using the computer assigned with press Enter.
9. Five replies to your ping should be indicated.
10. Once you get the two computers to communicate successfully together, you can now enjoy the benefits of file sharing, printer sharing and Internet connection sharing.
Jun 24, 2009 | Microsoft Windows Vista Ultimate Edition
Network a G4 (OS 9) to a eMac (OS X)
OK - first, crossover cables let you network PCs together without a switch or router. I would strongly recommend returning the crossover cable and buying a router so that you can use both computers on the internet at the same time.
Second, the eMac monitor can not directly be used as a monitor for your G4 - it's not built that way. However, you can use Screen Sharing on OS X (if both have Leopard) or Apple Remote Desktop software (if you buy it) to remote control the G4 using the eMac.
You will DEFINITELY need a monitor on the G4 in order to set it up at all, so I hope you have that.
Keep in mind that you can buy, for less than $200, an LCD screen that is larger and better quality than the eMac, and it would leave the eMac useful as a second computer. Since the eMac is unlikely to work at all with Leopard, and you'd have to buy Apple Remote Desktop, you're going to spend less money by buying a separate screen for the G4.
Nov 22, 2008 | Apple eMac G4 Desktop
Connecting a pc to a laptop
Have checked the IP address both should be in the same class like and
after setting the IP address
go to run type ping or 2 each other to ensure they are talking propely.
check the serviceability of crossover cable also.
Apr 19, 2008 | Cat5e 100 Foot Shielded STP 350mhz Network...
Pc's say a network cable is unplugged
First, NO, crossover cables are for connecting LIKE devices.. you need a Straight Thru cable for connecting 2 PCs to a switch.. So, if you are using Crossovers, then you are getting the correct results (cable unplugged). Replace with the proper cables, and it should see the network fine..
As this ProCurve HP 408 is 10/100 auto sensing, you should be able to automate speed and duplex within your NICs conifiguration...
Happy Holdiays!
Dec 22, 2007 | HP ProCurve 408 Networking Switch
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
204 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
