Question about HP LaserJet 4 plus Printer
Poor print resolution.
Greetings All; Am the proud owner of an HP Laserjet4+ and (up to now) it's been working fine. However (now) when I print, the printing contrast is very light (grey looking). I've checked the toner cartridge, it's okay (not low) and (also) tried a brand new cartridge - no difference! I've double checked the printer's settings (via the internal facilities) in case the settings may have been altered without my knowledge, but to no avail. Note! the print clarity is not affected, I.e. there's no smudging or marks on the paper, just light print contrast. I know it's not the software, as the problem exists when I use the (on board) self test facility. One thing, the machine was turned off for a long while (8 weeks) for safety reasons as the office wasn't being used. Any ideas? Please advise Thanks and regards Chris Dermott
  • 624 Answers
Ok, here is the list of things the typical user can check: -Toner supply could be low, even a new cartridge could cause this if it was a refill job, third party or very old. -Print density is set too low, change via the printers menu. -EconoMode is turned on, turn off via the printers menu. -The papers moisture, conductivity or surface finish may not meet specs, try a higher quality paper or a fresh ream. -High voltage connecter to the toner cartridge is not making good contact. Make sure the sprint contacts that connect the printer to the cartridge are making good contact and are clean. Here are the things to check that would require spare parts and are not for the typical user: -Transfer roller is defective or installed incorrectly. -Laser/Scanner is defective. -DC controller is defective. Let us know if you have any more questions for this topic and please don?t forget to rate the posting.
Posted on Jan 07, 2007
How can I print to my HP Color LaserJet 3550 from my Windows 7 Home Premium OS Toshiba Satellite C655 Laptop. The printer works, but HP says there are no drivers to support it. How can this be? Please...
If Hp does not have a drivr to support it then you are out of luck unless you find someone that hacked drivers to work with it. If they have Windows Vista drivers, you can try those but they are not goign to guarantee to work.
not all equipment from Xp works with vista or 7. Xp is not the same OS or even same breed as Vista/7
Apr 22, 2011 | HP DesignJet 3500cp InkJet Printer
I put in a new toner cartrige in my hp laserjet4 and it does not print very dark, whats the problem.
did you peel off the tape from the cartridge before installing it ?
when you want to print something, don't press the print button, select print review and selkect properties, make sure its not printing DRAFT --select fine
have you tried the print test
Oct 18, 2010 | HP LaserJet 4 plus Printer
Will HP laserjet4 plus print on card? If so how?
Depends on the weight (thickness) of the card. Assuming it's not too thick, feed it in through the manual tray (the flip-down tray on the front).
Feb 02, 2010 | HP LaserJet 4 plus Printer
Erro with printing using the lower try
you need to program it.. or you may try open the first try so that it will automatic print on the 2nd try
Aug 25, 2009 | HP LaserJet 4 plus Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
Printer is dark
Go to Start > printers and faxes> right click on the laserjet4 icon>
properties > click on printing preferences on the first page > click advance on the next page > under Graphics, you will see print quality. Change it to either 600x600 or 1200x1200. The higher the number, the darker the print.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 26, 2008 | HP LaserJet 4 plus Printer
Printer only prints half a page
this is a driver problem, try reinstalling the printer with the laserjet4 driver which is a universal PCL driver, this should solve the problem. If not, there is also a blank HP Laserjet driver
May 10, 2008 | HP LaserJet 5L Printer
HP 1610 - Skipping Lines when printing w/carriage return
You are lucky you can print ANYTHING! My unit has NEVER worked (3 years) due to a hardware defect of HP. I downloaded patches, cleaned/replaced cartridges, etc.
Spoke to HP last nite-Was told printer was junk-they don't carry it or any parts to fix it anymore!! I was told to replace it!
Apr 13, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
HP LaserJet4
In the printer driver, make sure you have the paper sizes set correctly  etc. Go over all the basics first.
Make sure that the options set under the "Device Settings" and "Advanced" tabs are relevant to your media and page sizes.
The chances are a setting in the driver has been changed by mistake.
Oct 18, 2007 | Office Equipment & Supplies
HP LaserJet 4 plus Printer Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
